Help with light switch
Bre
6 Aug 2006
Yorkshire
Fellas, i want to replace an old light switch. I\\\'ve bought a replacement fitting expecting it to be a straight forward job. i unscrewed the old fitting and it has three wires going into it, all of them red! Any ideas???
note what goes where and replicate the connections in the new switch? really, its not rocket science :rolleyes:
and they are all red because they are all live. shock horror.
three wires going into but are they going to three seperate terminals? if they are you need a 2 way switch , this has three terminals just copy original one of the cables must be in the common terminal if it is marked tho
followed crafty's advice (cheers crafty), i had 3 red wires going into seperate terminals, i lablled each wire and made sure that they went into the same terminal in new fitting (the new fitting is far newer than old so not totally same style. ... job done apart from now the lights in my other two bedrooms don't work! Any advice appreciated :idea:
2 of those lives must need to be linked. Is it a 2 gang switch (with 2 switches on the front)? if so, you need to link the 2 common terminals with a bit of red wire.
no, its just a one gang switch. The old fitting was really old and not quite the same as this new one i have. Don't get how refitting this would stop other lights from working.
well two of the cable were together internally maybe of the switch you will have to move one wire at a time you will end up with one wire in C or common and two in L1. it is sending out a perminant live to feed other lights by the sound of it
i'm thinking 2 of the lives are looping in (and need to be connected together in one terminal), and the other live is switched. How was the old switch wired? and how is the new switch wired?
EDIT: fireman that was as clear as mud. you been on the juice?
are you saying you changed the light switch AND the light fitting?
how did i miss that??? :eek:
fireman22 said:
no he his just talking about a switch . . . . i think
no, read this
how else would lights in other bedrooms not work if he only changed a switch?
very old switch seperate terminals but link of copper / brass between then, going up shed to find one for the manufacturer. and if he has changed both the switch and light fitting, with telling us i give up
new house, looping in at the switch. conduit install. hence 3 lives.
