Will not take water
20 Jan 2004
When on programm to take water machine takes it but in very few amount or even drops.
What could be a possible problem and how to solve it?
Thank you.
Aleksandar
Try it on a hot wash, maybe its just the cold supply bunged up. Check the pipe taps are on, ie spigot in line with the pipe. Check the filter where the pipe meets the machine. Check flow while the pipe is off, you may need a bit of ptfe tape to put it back again.
