I'm wiring an extension at present. I'm going to use an exisitng cooker radial circuit 4mm T&E (which I think might have a spur of it)...anyway...the shed will have a RCD and two MCB..one for light and the other for 3 double sockets 2mm T&E. I'm extending the 4mm to meet a 30 amp rated underground armnoured cable to the RCD in the shed ( I was going to use a 49 amp rated but this is to big?).
Is is ok to use the cooker circuit while having a ring circuit inthe shed?
Ireland has the same electrical setup as the UK.
