DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
cooker hood
This topic originated from the How to page called Installing a cooker hood
Click here to return to the page called Installing a cooker hood.
  View previous topic :: View next topic
Author Message
wikwik
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 26, 2006 8:09 am    Post Subject:
cooker hood
Reply with quote Thanks
Hi, my cooker hood fell from its mountings at 12pm last night! The plaster is quite bad but I do intend to remount it, but before I do is it compulsory to have a hood installed above an electric oven? Please advise on the regulations, thankyou
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Aug 26, 2006 8:18 am    Post Subject:
No one is obliged to have a cooker hood.
You can open a window or use an extractor fan if you like.
Q. Is the wall plasterboard, or brick/block (this afects how you refix it so it does not fall down again)
Q. Does your hood extract through the wall, or just recirculate?
Back to top
 Alert Moderators
wikwik
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 26, 2006 8:40 am    Post Subject:
cooker hood
Hi, thanks for such a quick response. The wall is brick and the hood recirculates. The wiring is still intact but there is a rather large hole where the right side mounting was. I am assuming the wall is suffering from damp.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Aug 26, 2006 8:58 am    Post Subject:
If the wall is brick, I'd suggest good long screws when you refix. Two inches is not too long. If using ordinary brown plugs, tap them well down inside the hole, by putting a few turns of the screw on them, then tapping the screwhead lightly with a hammer before you finish screwing then tight. You can also get curiously long screws and plugs that are used for fixing doorframes.
If I guessed the reason for it falling off, I'd think one or more of:
    Short screws and cheap little plugs provided with the hood
    Loose hole from the incorrect size of drill, or a non-hammer-drill taking a long time and rattling about in the hole
    Screwhole drilled into softish mortar instead of a firm brick or block.
p.s. if it just recirculates, it is almost entirely useless. Is it mounted on an outside wall? If not an extractor fan will do more good.
Back to top
 Alert Moderators
wikwik
from United Kingdom
Thanked: 0 times
PostPosted: Sat Aug 26, 2006 9:09 am    Post Subject:
Hi, thankyou so much for your help, I do have good ventilation in the kitchen so will probably lose it as it was fixed to an inner wall and a kitchen refit is not on the cards for a long time yet as I have only just moved in, Thanks once again!
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sat Aug 26, 2006 4:04 pm    Post Subject:
Re: cooker hood
please dont use the words "oven" and "cooker" interchangeably, they are different things altogether. icon_wink.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
New Cooker Hood 7 180 Thu Jul 16, 2009 8:26 pm
Cooker hood - OK to spur off the radiul cooker circuit? 14 1100 Fri Sep 24, 2004 6:18 pm
cooker hood 4 3500 Sun Feb 12, 2006 1:00 pm
FCU for cooker hood 7 340 Sun Aug 17, 2008 1:01 pm
Cooker Hood, supply? 2 200 Sat Feb 23, 2008 7:15 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
