i am replacing a mixer tap with a pullout mixer tap, i have the 2 flexi hoses but as this is a pullout their is a third hose on the tap where do i fix that to. please help if you can. thnk pp
One is your hot water inlet one is your cold water inlet and the third is the mixed water to the pull out head. It will connect to a small tail that sticks out of the bottom of the mixer. Check the instructions. Make sure you fix the weight on the pull out to help it retract the hose.
thanks cozzmic, got that sorted , im now having trouble fitting the flexi hose to the original coper pipes, they do not seem to be compatable, ive been told about getting a compression valve is this correct. no instructions where supplied with the tap
