Whirpool 6th sense
3 Sep 2006
Middlesex
Washing machine leaks from bottom of door during wash cycle. Also door lock light remains on at all times when machine is on. Door seal seems OK, is there any adjustment on the door that can be made? Or any other suggestions you may have to cure the problems.
No adjustment on the door but make sure it hasn't dropped or that the hinge screws aren't slack. Clean the door glass and seal face. Check the front panel hasn't bent inward. If still leaking you can only try another door seal.
