DIYnot
Local | Network
   DIYnot > Forums
Local | Network
webcam as cctv for drains??
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Hardware
Author Message
onion_soup
from United Kingdom
PostPosted: Sun Sep 17, 2006 10:20 pm Reply with quote
is it possible ?
TIA
Back to top
 Alert Moderators
Igorian
from United Kingdom
Thanked: 63 times
PostPosted: Sun Sep 17, 2006 10:59 pm Reply with quote
Probably.
Back to top
 Alert Moderators
onion_soup
from United Kingdom
PostPosted: Sun Sep 17, 2006 11:53 pm Reply with quote
Igorian wrote:
Probably.
lol need a technical answer ... max length of usb etc
what happens if cam gets stuck ? and which cheap cam to use ?
TIA
Back to top
 Alert Moderators
Igorian
from United Kingdom
Thanked: 63 times
PostPosted: Mon Sep 18, 2006 12:18 am Reply with quote
It will be pants, I really wouldn't bother.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 415 times
PostPosted: Mon Sep 18, 2006 12:26 am Reply with quote
Why not get a small CMOS camera from CPC and hook it up to the scart socket on your TV / VCR. You'll need a power supply and a small light source too.
Back to top
The following user says thank you to Spark123 for this useful post:
onion_soup (12 Sep 2011)
 Alert Moderators
keifster
from United Kingdom
Thanked: 1 time
PostPosted: Mon Sep 18, 2006 9:02 am Reply with quote
I think the maximum length of USB is only about 5m.
Back to top
The following user says thank you to keifster for this useful post:
 Alert Moderators
eggplant
from United Kingdom
Thanked: 2 times
PostPosted: Mon Sep 18, 2006 10:28 am Reply with quote
How big are the drains? do you need a camera thats a certain size?
How about an IP camera? the ones we have here also have IR built in so can see in the slightest of light.
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 2 times
PostPosted: Mon Sep 18, 2006 1:58 pm Reply with quote
I dunno, sounds a bit like why not use the kitchen knives instead of expensive screwdrivers?
Back to top
 Alert Moderators
onion_soup
from United Kingdom
PostPosted: Mon Sep 18, 2006 6:32 pm Reply with quote
There is no tv nearby but have a laptop. Will look at CPC website cmos camera maybe be better .
The drains were blocked upto bath/basin but blockage was in 4'' soil pipe.
Need to have a look in plastic to clay join all the way to manhole cover if possible for stones/breakage/partial collapse, before breaking up concrete patio.
Do you have a link to IP camera ?
TIA
Back to top
 Alert Moderators
eggplant
from United Kingdom
Thanked: 2 times
PostPosted: Mon Sep 18, 2006 6:41 pm Reply with quote
http://www.axis.com/products/video/camera/
beear in mind, azis are by no means the cheapest but they are excellent - mind you I dont think I'd be wanting to put one down a drain! There are cheaper IP cameras available, the reason I posted that link is theres a lot of info on there.
Back to top
The following user says thank you to eggplant for this useful post:
 Alert Moderators
Igorian
from United Kingdom
Thanked: 63 times
PostPosted: Tue Sep 19, 2006 6:55 am Reply with quote
Oh come on, be serious, a webcam down a drain?
How will you guide it and then position it so it is looking at the correct place? The lens will more than likely get covered in whatever crap is down there and, at worst, damaged.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 415 times
PostPosted: Tue Sep 19, 2006 11:26 am Reply with quote
You can a cheapy usb-video capture device and plug it into the laptop so you can display the picture from a bog standard cmos camera. Supply from a battery to run the camera. Like Igorian says webcams ain't the best thing to be shoving down a drain, in comparison they are quite bulky, unlikely to be waterproof and the lens will get covered in no time. The only real viable option I can think of is to get a small waterproof camera and have a waterjet to clean it off?
Back to top
 Alert Moderators
eggplant
from United Kingdom
Thanked: 2 times
PostPosted: Tue Sep 19, 2006 1:56 pm Reply with quote
But then you are back to the 5m cable length
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 415 times
PostPosted: Tue Sep 19, 2006 9:04 pm Reply with quote
I really ought to explain myself better icon_wink.gif.
I meant plug a USB-Video convertor into the laptop and run a coax component signal cable from the "video in" to the camera along with a power signal (and hose?) you can go quite a long distance with coax.
This way the USB-Video convertor makes the laptop behave just like a CCTV monitor.
Back to top
 Alert Moderators
eggplant
from United Kingdom
Thanked: 2 times
PostPosted: Tue Sep 19, 2006 9:36 pm Reply with quote
I see !
but why not just use an IP cam instead? either way, methinks a camera down the drain (a camera of the type we are talking about) isnt a good idea unless the camera is sort of in a straight line down the drain - in which case surely a torch would be a cheaper and easier option - or am I missing something?
Out of interest, what sort of quality can you expect (assuming a decent cam) from a usb convertor? cant say as I've ever come accross them but may be of use.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Hardware All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
I want to connect 2 networks 1 my internet and other my CCTV 11 1020 Thu Mar 25, 2010 8:50 pm
CCTV 4 560 Sun Apr 16, 2006 6:16 pm
Webcam 4 400 Wed Apr 25, 2012 7:59 pm
Microsoft Webcam Broke Vista? 6 600 Sat Nov 15, 2008 10:28 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
