| Author |
Message |
izzy207
Joined: 03 Feb 2004 Posts: 3 Location: United Kingdom
Posted: Tue Feb 03, 2004 6:40 pm |
could someone please tell me how i can fix my upvc door its jammed shut and will not unlock, how do i get it open to repair. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
masona
Joined: 05 Jan 2003 Posts: 12359 Location: Essex, United Kingdom Thanked: 99 times
Posted: Tue Feb 03, 2004 6:42 pm |
Is the handle working up & down okay or the key won't unlock ? |
| Back to top |
izzy207
Posted: Tue Feb 03, 2004 6:50 pm |
the handle is loose, the key wont unlock it. |
| Back to top |
masona
Posted: Tue Feb 03, 2004 6:56 pm |
I'm afraid it might have to be drilled out by locksmith,but read this first. |
| Back to top |
izzy207
Posted: Tue Feb 03, 2004 7:00 pm |
thanks for your advice. |
| Back to top |
wossie6
Joined: 18 Mar 2003 Posts: 112 Location: United Kingdom
Posted: Wed Feb 04, 2004 5:13 pm |
i had the same problem,only my door was two year old,it is a milla locking system,but as the door was not bought by me but from a firm that went bust,i lost the gaurantee.will cost about £70,the way the door had been fitted it caused wear and something crumbled. |
| Back to top |
williams1
Joined: 09 Feb 2004 Posts: 2 Location: United Kingdom
Posted: Mon Feb 09, 2004 4:29 pm |
as with most of these doors you should be able to get at the hinge pins
tap these upwards and the pins should come out, you can then remove
the door from the hinge side |
| Back to top |
bens747
Joined: 22 Apr 2004 Posts: 10 Location: United Kingdom
Posted: Thu Apr 22, 2004 6:19 am |
I lost my key to the patio door and called out a locksmith which cost £70.00. All he did was drill out the lock and removed the affending article which can then be replaced with another lock purchased at nay DIY store. Much cheaper than £70.00 |
| Back to top |
salem2000
Joined: 10 Feb 2004 Posts: 611 Location: Essex, United Kingdom Thanked: 4 times
Posted: Thu Apr 22, 2004 6:38 am |
| williams1 wrote: | as with most of these doors you should be able to get at the hinge pins
Use great care when using this method.
When the main lock is engaged on some of these doors, bolts are also thown into the top/bottom rail of the door frame. Severe damage can result, requireing complete replacement. |
| Back to top |
