Hi I have a uPVC exterior door which is locked by turning the handle up and then turning the key. Recently the key has been sticking and won't lock the mechanism without a struggle. The handle turns up smoothly and isn't tight but the key action is causing the problem. If I repeat the process with the door open it works perfectly, very smooth as expected, but as soon as the door is closed the key sticks.
I changed the lock cylinder with that from another uPVC door but the problem was still there.
Is this something I can possibly fix myself without calling out a locksmith?
