Clogged Washing Machine Drawer
26 Sep 2006
i have a zanussi jet 1000 and it has a drawer with max on the r/h/s.for conditioner but it is always full of water is this right is this to mix water with cond.
frank :confused:
Most likely the compartment outlet (which is probably two plastic tubes overlapping each other) is clogged. This often happens, sometimes with old fabsoft but more often when people put soap powder in the conditioner compartment. Take the drawer out and scrub it in hot water. look carefully at how the conditioner compartment comes apart. Scrub out the slot where the drawer goes into as well. If you see black mildew, spray it with Kitchen Cleaner with Bleach before you scrub. a nylon-bristled washing-up brush is handy here. Rinse well and give it a HOT wash with no powder or laundry to clear away the congealed old sludge.
If the dispenser is that bad then it's likely the tub is bad too.
1 aerial tablet into the drum and hottest wash with no laundry will help. It has a high bleach content which helps kill the bacteria.
