I have just had a Salamander ESP CV75 shower pump installed alomg with some thermostatic bath taps. As bath taps didn't appear to working properly in that the water wasn't very hot even when the temperature control was set to the highest (ie over-rode safety stop) I cleaned the filiters on the tap inlets but still no joy. As the tap pillars were getting hot I knew hot water was getting to the inlet so I thought perhaps the cold was at a higher pressure than hot and hence causing a problem. So I stopped down the gate-valve on the cold water feed from the tank to the shower pump - but checked that there was still some cold water flow by turning on the basin tap.
This didn't solve the problem so I opened gate valve fully again. A bit later I ran my daughter a bath with the tap temperature control on full so at least she had a luke warm bath. Pump was running for about 10 mins. Upshot of this is that unbeknown to me the pump was spewing out water in the airing cupboard and leaked through ceiling. The pump is now 'spraying' out water out of what I would describe as the end cover (the large round bit that has about 6 threads through with nuts each end) on the cold inlet side of the pump whenever the pump runs. (doesn't seem to leak when pump not running).
Anybody any idea what has heppened - have I managed to destroy a seal or something, have I trashed the pump or do you suspect it was a faulty pump. This pump has 'dry-run' protection so should have cut out if I had inadvertantly cut the cold flow right off. If it is a seal can they be replaced.
(By the way I only starting fiddling as it was the weekend, we needed to have a bath/shower working and my plumber was away and I thought it would be simple to get the taps working. Next time I will definitely leave well alone )
