The water coming from the shower, not as hot like other taps
5 Oct 2006
London
Hi.
Just moved into a 1930's house. Noticed that the shower (thermostatic) has full water pressure/power, but appears that the water coming from it is luke warm when the lever is turned all the way to the hot position.
The hot water tap beneath it and throughout the house are all boiling hot. Even the radiators are hot when the heating is on.
Additional info: The boiler is ON and called, "BAXI". All lights for "Boiler", "Fan", "Pilot" and "Burner" are all ON and the thermostat control knob is set to the third (middle) bar. I have tried turning this thermostat knob to it's highest (maximum) point. As a result, the shower was slightly hotter but not hot, and I found that the hot water taps throughout the house were scalding HOT!!! So, I turned the thermostat knob back to it's original (middle) position on he boiler.
There is another unit next to the boiler, in the airing cupboard called, GRUNDFOS SELECTRIC, which is set to level 2.
Please can you help?
Thanks,
M
A thermostatic mixer should adjust a bit hotter than anyone would want for a shower.
Your cartridge has either packed up - they don't last forever, or needs adjusting to get it back into range.
They're all different and cheap ones don't adjust at all. You won't get a cartridge for the cheaper ones either. Look around the retailers to see if you can identify the make.
Hi Chris R, Thanks for the advice, but unfortunately I have't got a clue about DIY skills to change a cartridge of a thermostatic shower unit. Thanks anyway.
Anyone got any advice on how to check / change a cartridge in a thermostatic shower unit? When I say 'advice'...I mean for a DIY virgin. Thanks
