Hi all,
Fitting a new kitchen. We've currently got a 30A standard control switch and the terminal box..
I need to fit a double under oven rated at 4.2kw, and an induction hob which is stated on the website as being "Total electrical connected load (kW): 7.2 ".
now, from what i understand i need to connect the hob to the 30A supply on its own, and i can run a fused spur off the 30A suplpy to run the oven.. is this right? Or can i wire in BOTH the hob and oven into the 30A outlet terminal?
Any help appreciated..
