No water flow in Mira sport
9 Oct 2006
Glasgow
Have an electric Mira Sport shower, older model, Just a dribble of water coming out. If you place finger over pipe with shower head off you can feel hot water or cold depending on setting. Is this a deceased shower or can it be fixed !!!
In the mira sport at the top left were the water comes in you will find a gauze filter.
Isolate the water and electric supply, remove the brass cover and earth wire and clean out the filter.
Remove the shower head and descale, also try running the unit with the shower head removed to see if this alieviates the problem.
If non of the above cure the fault it would be likely that you have a faulty inlet solenoid.
This is the large white/beige or black plastic unit just to the left of the water feed, it as 4 small micro switches attached to it.
This unit can be purchased directly from Mira and replaced.
