DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Intermittent Hot Water
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
SunnyC
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 24, 2006 10:42 am    Post Subject:
Reply with quote Thanks
Hi all
I moved a rad (this is where the problems started!) but knackered one of the valves in the process – so ended up draining the whole system (some of it through the kitchen ceiling).
Anyway, managed to fix it – put the rad back on & represurrised the system.
I bled the air from the radiators (but have since read that I should have been more methodical – I just bled from upstairs to downstairs).
The heating has been fine but we have now noticed that the hot water is hot & then goes cold for about 5-10 seconds before getting hot again. This has just happened, and the HW was fine before. Please could you advise? Do I need to bleed the rads again? Can I bleed the HW part of the system? (is air the problem??)
Any help, much appreciated!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Wed Oct 25, 2006 7:28 am    Post Subject:
Boiler?
Back to top
 Alert Moderators
SunnyC
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 25, 2006 8:44 am    Post Subject:
Alphason Combi Boiler (sorry, thought I had posted that) - will check model when home....
Back to top
 Alert Moderators
SunnyC
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 25, 2006 8:57 am    Post Subject:
problem seems to be worse upstairs with shower (boiler is downstairs). This morning, shower water was hot for 2 mins then became tepid. Have rebled all radiators.
Back to top
 Alert Moderators
gigz
from United Kingdom
Thanked: 4 times
PostPosted: Wed Oct 25, 2006 1:15 pm    Post Subject:
Turn off the boiler and bleed from downstairs first then upstairs. Your diaphram washer could be split and need replacing, this could possibly be the cause of your hot water temp fluctuating.
Back to top
 Alert Moderators
SunnyC
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 20, 2007 11:56 am    Post Subject:
Hi - thx for the advice. Finally got BG out (under homecare). They charged me 250 for a new DHW HExchanger - as it was blocked apparently. Now, nearly 5 months later - the same thing is happening. Except this time, they say I need a powerflush too! They are "willing", after some persuasion, to replace he HE for free, if I have the powerflush (£600!). Any advice guys? Can I clean the HE? I have some Ferroquest - am thinking of using it on the system (not sure if I should - i.e. is the HE aluminium?) but with the hot water tap turned on for a few hours (to divert the flow over the DHW HE).
Will this work? ? any advice gladly appreicated.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Tue Mar 20, 2007 12:07 pm    Post Subject:
Its unlikely to do any harm but may not clear the plate HE.
Close the rad valves and use the boiler for DHW for a few hours. Then open the rads and use the heating for a day or so before draining and refilling with inhibitor.
All I can say is that an independent firm would be likely to be a lot cheaper for that kind of work.
Tony
Back to top
 Alert Moderators
SunnyC
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 20, 2007 12:12 pm    Post Subject:
Many thanks for the super quick reply Tony. Do you know if the Ferroquest product is suitable for this boiler (think you should avoid aluminium if poss)?
Also, I am a novice, so apologies but...
1. Should I close ALL valves? thermo and lockshield?
2. When you say use for HW - do you mean just switch it to HW mode only - or actually switch and run the HW tap continuously for a while?
Best
Back to top
 Alert Moderators
SunnyC
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 20, 2007 1:49 pm    Post Subject:
Sorry - should be a Alpha Combi (CB24 I think) boiler - not an ALPHASON!! (who make speakers I think?)
Back to top
 Alert Moderators
SunnyC
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 23, 2007 9:22 am    Post Subject:
anyone still listening?
If i take out the DH HE and try to descale it, will I have to
- drain down? (only reason I ask, is that the BG guy didnt when he replaced it)
If I try to descale/clean the primary, will I have to drain and turn off gas?
Best
Back to top
 Alert Moderators
2face
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 23, 2007 11:05 am    Post Subject:
bg always do this, scare u with a powerflush . 600 ???? were do they arrive at this sum ..
cancel the homeserve and get a local engineer to fix it for you.
up here powerflush is generally 300
the last 1 i bought came in at 150 ish inc vat ..
it is a part regularly fitted on alpha boilers so probably a weak point
__________________
plumbing,heating,solid fuel and electrical services.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Intermittent Hot Water - Alpha 240E 9 860 Mon Dec 04, 2006 12:04 pm
Scalding water but intermittent heating on timer - 'Ideal' 4 420 Tue Jan 24, 2006 9:35 am
Intermittent hot water 9 120 Sun Mar 22, 2009 2:06 pm
Intermittent water pressure upstairs 3 400 Sat Jun 23, 2007 3:46 pm
Intermittent hot water problem with Ideal Isar HE24 20 2680 Mon Oct 20, 2008 8:23 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
