DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Conservatory electrics
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
BillyB95
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 28, 2006 2:13 pm    Post Subject:
Reply with quote Thanks
Seeking advice regarding Section P. Various sites are offering up conflicting advice.
Would I be breaking the rules if I extend, via a 13A fused spur, an existing circuit (one cable spur) into a planned conservatory (adding 2 double sockets)?
Would appreciate any guidance.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Sat Oct 28, 2006 3:04 pm    Post Subject:
No problem doing that. Its just a spur from an existing ring and not notifiable as conservatory does not count as 'outside'.
BUT (there's always one) the existing ring must be protected by RCD so your sockets meet the criterea for those that may be used to power prtable equipment outdoors.
TTC
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sat Oct 28, 2006 4:13 pm    Post Subject:
if RCD protection is an issue you can always use RCD sockets in the conservatory, its only a couple of sockets so it won't break the bank.
Back to top
 Alert Moderators
BillyB95
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 28, 2006 5:38 pm    Post Subject:
Many thanks for your advice.
The consumer unit was changed 4 years ago for a more modern one, incorporating RCD, so that should cover it.
I'll replace the existing spurred socket with a 13A fused sur and run the double sockets off that and into the new conservatory.
The lighting won't be a problem as the outside light will be enclosed within the conservatory. I'd better change the light fitting though, as the minister for war and transport will, naturally, want a 'nicer' light ! Bless her !
Cheers.........BB
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Conservatory electrics 9 740 Fri Apr 14, 2006 11:42 am
Conservatory electrics 9 300 Fri Jan 02, 2009 4:51 pm
Conservatory Electrics question 2 360 Wed Sep 26, 2007 6:32 am
Conservatory electrics - extra double socket question 7 440 Sun Nov 02, 2008 11:29 am
Conservatory Electrics 4 420 Tue Feb 26, 2008 8:56 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
