DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Help - Leaking radiator
This topic originated from the How to page called Fixing a leaking radiator
Click here to return to the page called Fixing a leaking radiator.
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
MarkTasha
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 16, 2006 9:20 pm    Post Subject:
Reply with quote Thanks
I have a leaking radiator. I have turned off both valves to stop water entering the radiator and am trying to drain it off. For some reason, though, water is still coming out (so far, a washing up bowl of it).
The leak appears to be on the pipe between the balance valve and the radiator itself.
Any ideas how I can stop this thing leaking in the short term?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
scatmanjohn
from Colombia
Thanked: 4 times
PostPosted: Thu Nov 16, 2006 9:28 pm    Post Subject:
How big is it?
There is a lot of water in a radiator.
If you open the bleed nipple is water still coming out even after you have drained out loads?
If not just keep draining, it will stop.
Back to top
 Alert Moderators
MarkTasha
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 16, 2006 9:42 pm    Post Subject:
Okay, thanks for the reply. I'll persevere.
It's a single, standard rad, about 1.5 meteres in length
Back to top
 Alert Moderators
MarkTasha
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 16, 2006 10:31 pm    Post Subject:
Hmmm, water still pouring out of the rad. How long can this go on?
I took off the bleed valve and water was shooting out. It's as if the radiator isn't isolated, despite me tightening up the lockshield valve
Well, looks like I'm going to have to get a 24hr plumber (= very expensive) if I want to go to bed tonight.....
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Thu Nov 16, 2006 10:34 pm    Post Subject:
have you shut off both valves?
__________________
If at first you don't succeed, remove all evidence you ever tried.
Back to top
 Alert Moderators
MarkTasha
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 16, 2006 10:36 pm    Post Subject:
Yep, did that. Admittedly, it is an old radiator, but surely I should be able to isolate it......
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Thu Nov 16, 2006 10:37 pm    Post Subject:
was one of them a thermostatic one
how big is the rad there may be a lot of water in it to come out
__________________
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu Nov 16, 2006 10:43 pm    Post Subject:
Best tie up the ball valve in the Feed & Expansion Tank (if you have one) or make sure the filling loop is turned off (if not).
It is possible your old rad valves are not sealing tightly.
Back to top
 Alert Moderators
MarkTasha
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 16, 2006 10:44 pm    Post Subject:
Yes, one is the thermostatic valve. The other is the lockshield valve (I think that is what it is called. Turned them both clockwise until they wouldn't turn any further.
Rad is 54'' x 24'' (just measured it!) Currently onto 2nd washing up bowl of water.....
I will really resent having to get a plumber out as we have one booked in early December in any case...
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Thu Nov 16, 2006 10:46 pm    Post Subject:
the TRV aint shutting right
sorry
__________________
Back to top
 Alert Moderators
MarkTasha
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 16, 2006 10:49 pm    Post Subject:
Okay, thanks for your reply, but I have no idea what these are. How might I turn of the 'filling loop'? I'm guessing the feed and expansion tank is the thing in the loft (not even sure we have one). Have to say I'm tempted to turn off the water at the mains so that I can at least go to bed!
Sorry for my ignorance, but then I guess it is people like me that keep plumbers in business!!
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Thu Nov 16, 2006 10:50 pm    Post Subject:
do you have a small tank in the loft?
if so tie up the ballvalve so that no water can get in
__________________
Back to top
 Alert Moderators
MarkTasha
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 16, 2006 10:52 pm    Post Subject:
sorry
That is the thermostatic valve, right? Does that mean I'm stuffed?
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Thu Nov 16, 2006 11:03 pm    Post Subject:
well unless you drain the system
yes
sorry
__________________
Back to top
 Alert Moderators
MarkTasha
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 16, 2006 11:05 pm    Post Subject:
Nope, no tank in the loft. If I turn off the water at the main, will that stop it for tonight? How long would I have to wait until it stopped leaking?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 3
Jump to:
Radiator leaking out and boiler pressure gone up to 4!! 18 300 Sun Apr 05, 2009 4:04 am
Leaking Towel Radiator - Screwfix 3 400 Tue Jan 27, 2009 2:07 pm
Leaking radiator tails - new install 7 300 Thu Nov 27, 2008 9:35 am
DRAYTON TRV4 THERMOSTATIC RADIATOR VALVE - leaking 2 1480 Tue Dec 21, 2004 9:34 am
Leaking Radiator 9 380 Sun Dec 30, 2007 5:57 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
