Underground Cable Size
28 Nov 2006
Hello
I am in the process of starting to build a boat house (workshop) near to my property.
It will have heavy voltage use such as welders etc and lights and heating.
My problem is that an electrician i have asked said that the best way is to bury the cable underground from my house and it should be big enough to power a house and may have to be 25square or 35square armoured because of the amount of power i will use, he wasnt sure what size exactly.
The distance along or under the path is 90 meters and it will be 240 volt.
I cannot or do not want a new overhead connection fitted because i am told i will have to remove many trees which will devastate the place.
I want everthing ready for when each workman is to start so can somebody tell me 1. What size cable and 2. Where is the best place to buy it from over the internet if it works out cheaper.
Nothing to do with me
Mod Rupert
Do you have (or are you getting) a 3 phase supply to you property? or will the house and shed be fed off a single phase supply?
What size welders etc will you be using?
How many big and small tools will you have in the workshop?
RF the poster did say
Mr Bear, it really depends on the load as to the cable size, (then distance which we know) thatis why RF is asking what you will be using (its rating) so an answer can be given
:eek: Heavy Voltage ?????
I think we need to know what the total 'loading' in watts or amps that you intend to require at this boat house is. As advising on "as much as a house" could be a bit mis-leading and end up with you getting the wrong figures for your calculations.
I don't mean to sound abrupt, but need to know more to advise properly.
Have you a single phase supply ?
Main fuse rating at the head ?
Cheers
Bit late, sorry ! :oops:
I have 240 volt at the house standard electrics but at the boat shed there will be lighting and a couple of electric heaters together with my mig welder which is 240volt, my work is repairing and hopefully manufacturing small Aluminium boats and associated work.
Other equipment will be just power tools i.e. grinders and drills etc.
They're asking for max Amps load (or Watts).
thats nice, but we still need to know the rating, not the voltage
Maybe if you found out the maximum demand , in amps, that your existing house needs, then take that away from the main fuse rating and it leaves you with what you have left for use !!!!!!!!!!!! :LOL: :LOL: :LOL:
Not much......
Sorry the max power on my mig welder is 350 amps but i hope to have another man helping me so there will be more than one tool/machine in operation together with the usual things.
That's (hopefully :eek: ) the secondary current of the welder.We need to know the primary current ie does the welder plug in a standard 13A socket or some other method.There might be a rating plate on the side casing?
OK, well you go away and work out the total wattage of your equipment, and decide what will be that max you will use at any time, then come back and tell us.
The alterative is for us to guess, which is useless.
My welder plugs into a plastic 3 pin socket the industrial type that you screw together not the small household plug, all welders have this type of plug for 240 volts
