DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
More Showers
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
drunkenengineer
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 10:32 am    Post Subject:
More Showers
Reply with quote Thanks
I currently have a Gainsborough RE600 shower (rating unknown) and intend replacing it with a Triton 9.5kW shower. The cable is 4mm.
Is this a problem? I think the RE600 is 9.5 but am not sure.
By the way, I'm a clanky type, not a greeny!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Wed Nov 29, 2006 11:22 am    Post Subject:
Do me a favour. Open the shower switch up with the power off, and tell me what you see.
50p says its full of melted plastic and the switch no longer operates. If it isn't you've been very lucky indeed.
Dont use the shower again until you've replaced it with at least 6mm². However, since you're replacing the cable, you might as well go for 10mm².
4mm² will carry 37A IIRC, if run in free space. Your shower is 41 amps (ish)
Back to top
 Alert Moderators
scousespark
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 29, 2006 12:13 pm    Post Subject:
the RE600 is 8.5Kw, so 4mm is okay but you need to upgrade for a 9.5Kw shower. As crafy said, 10mm should be okay - unless you have a long run or the cable is affected by external factors (eg run through insulation)
Back to top
 Alert Moderators
drunkenengineer
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 30, 2006 11:39 am    Post Subject:
Thanks to both
Didn't know the RE600 is 8.5 (lost the paperwork). Ill get a new cable run in.
Crafty, 50p please.
DE
Back to top
 Alert Moderators
WF100
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 09, 2007 12:38 pm    Post Subject:
Voltage Drops
icon_question.gif Hi Guys, I am not an electrician, but doesn't the current draw go up as the voltage goes down? i.e. if the voltage dropped to say 220V(I have seen this many times) the cable will need to carry nearly 39 amps.
So I am assuming that 4mm should not really be used???
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Thu Aug 09, 2007 12:59 pm    Post Subject:
Re: Voltage Drops
if the voltage goes down, then you need to increase the current *in order to maintain a constant power* (Power = Voltage x current), in a resistive load this doesn't happen, the current actually reduces as well (Current = voltage / Resistance),
9.5kw shower on 240v will take 9500/240 = 39.58A and has a resistance of 240/39.58 = 6.06 ohms
Put the same shower on 230v and the resistance is still 6.06 (its about the only thing thats constant-ish here), which means it'll draw 230/6.06 = 37.95 Amps, which gives it a power of 37.95 x 230 = 8.73kw (the change in power is in proportion the the change in voltage squared - [ P=V²/R])
Regardless of which, neither 4mm² nor WF100 would do! (I wouldn't put it past some though!)
Back to top
 Alert Moderators
FatGit
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 09, 2007 1:05 pm    Post Subject:
I remember once being told by a drip that they always use 6mm2 cable on a shower as it is easier to work with icon_eek.gif
He tried to use it on mine until I said he was putting in 10mm2 and I watched him do it.
Back to top
 Alert Moderators
CallEdsFirst
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 09, 2007 2:29 pm    Post Subject:
Re: Voltage Drops
Wasn't there a picture not so long ago of a socket wired in coax???? icon_eek.gif icon_lol.gif
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Thu Aug 09, 2007 2:36 pm    Post Subject:
Or bind the cable to the cold water pipe, cools the cable and pre-heats the water......
That is a JOKE..... DO NOT do it.
Back to top
 Alert Moderators
SUNRAY
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jul 28, 2009 11:26 pm    Post Subject:
Sadly seen it done and frequently
Also seen cable run INSIDE the water pipe to a shower
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Tue Jul 28, 2009 11:44 pm    Post Subject:
Re: Voltage Drops
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Goldberg
from United Kingdom
Thanked: 44 times
PostPosted: Wed Jul 29, 2009 12:04 am    Post Subject:
I think you haven't.
I'm sure you haven't.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Jul 29, 2009 12:07 am    Post Subject:
How would that work?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Goldberg
from United Kingdom
Thanked: 44 times
PostPosted: Wed Jul 29, 2009 12:12 am    Post Subject:
SUNRAY
from United Kingdom
Posts: 1 useless contribution
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Jul 29, 2009 12:19 am    Post Subject:
Ah - that's a difference between you and I.
I see absolutely no point in mincing around with euphemisms - the meaning is clear and doesn't change, so what's the point in putting lipstick on a pig? Use the L word....
__________________
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
how to wire 2 electric showers on the same circuit 11 860 Fri Aug 17, 2007 8:41 pm
Renew showers kw?? 3 340 Sun Jul 22, 2007 11:08 am
Showers! 6mm T&E cable to be used for shower 6 860 Sun Aug 19, 2007 10:11 am
2 electric showers 2 300 Fri Aug 24, 2007 11:18 am
mira showers 6 320 Mon Dec 10, 2007 6:12 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
