DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Lighting from ring main
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
r1rider
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 02, 2006 6:03 pm    Post Subject:
Reply with quote Thanks
Hi..could someone please tell me if it is acceptable to spur off a ring main to a light in 2.5 T&E so that an FCU is not needed..Someone asked me this and i could not find a reg that conflicted? Thanks guys icon_biggrin.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Dec 02, 2006 6:06 pm    Post Subject:
fcu is required
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sat Dec 02, 2006 6:11 pm    Post Subject:
i belive it is not considered safe by the regs to put BC or ES lampholders on a protective device above 16A or to put SES or SBC lampholders on a protective above 6A but i'm not positive.
for other types of light its down to the manufacturers instructions.
Back to top
 Alert Moderators
r1rider
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 02, 2006 6:14 pm    Post Subject:
thanks but where or what reg states this ..surlely the ring main fuse is to protect the cable and if in 2.5 then the cable is protected.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Dec 02, 2006 6:22 pm    Post Subject:
yes the cable is, but the light isnt
__________________
Forum = Opinions
Back to top
 Alert Moderators
r1rider
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 02, 2006 6:27 pm    Post Subject:
I guess not unless the light is fused internally ..just trying to avoid having another point on an already crowded wall. Thanks for the opinions guys (still didnt get a reg though!!) icon_lol.gif
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sat Dec 02, 2006 6:32 pm    Post Subject:
you can use the FCU as the swtich btw
you can also use something like grid plus to put one fuse and a group of switches on a single plate.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Dec 02, 2006 6:35 pm    Post Subject:
If you're fitting an FCU, put a 5A fuse in it. Then your lighting spur is properly fused. And it only needs to be 1.5mm (or 1mm if you're mean).
If it was me I would put a durable label on the FCU "Lighting circuit: 5A Fuse" as someone will one day want to put a brown one in there.
BTW I would have sworn that ordinary light switches and lampholders are manufactured to carry 10A max, and the small SES or SBC are made for 5A max. So they would not be "suitable" (catch-all) for a 13A or higher circuit.
Back to top
 Alert Moderators
r1rider
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 02, 2006 6:42 pm    Post Subject:
as i stated i was looking for a reg that does not allow lighting on a 2.5 without an FCU, assuming the light is rated or internally fused accordingly then i can find no problem with this?
I am by the way an approved spark and am aware of the function of spurs icon_rolleyes.gif
Back to top
 Alert Moderators
r1rider
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 02, 2006 6:54 pm    Post Subject:
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Sat Dec 02, 2006 6:55 pm    Post Subject:
May not be a reg to prevent this but would you call it "good practice"?
Back to top
 Alert Moderators
r1rider
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 02, 2006 6:58 pm    Post Subject:
I would not call it bad practice if it satisfied the regs.
Back to top
 Alert Moderators
WSDLTD
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 02, 2006 7:18 pm    Post Subject:
its called isolation and seperation of circuits and although you might not find a specific reg that says this if you require a certificate in the near future for insurance or selling the house theres no way that it will get signed off.
Back to top
 Alert Moderators
r1rider
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 02, 2006 7:41 pm    Post Subject:
I have 2391 inspection and testing and see no relevance in your comment..sorry but i disagree..you do not need seperation of these circuits and neither do you need isolation other than that afforded by the breaker at the cu. icon_wink.gif
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Dec 02, 2006 7:44 pm    Post Subject:
so you would quite happily wire a 60w light into a ring main with no fcu?
__________________
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
fluorescent lighting spur from ring main socket. 6 640 Sun Mar 04, 2007 6:21 pm
Ring main and lighting off a single circuit? 4 420 Tue Nov 04, 2003 11:41 pm
Ring main, lighting. 4 680 Sat Sep 08, 2007 12:17 pm
Extending Socket Ring Main and adding a lighting spur 12 1640 Tue Oct 02, 2007 5:35 pm
lighting spur from a ring main/socket 25 5820 Sun Dec 02, 2007 10:22 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
