walk
Joined: 05 Dec 2006 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Tue Dec 05, 2006 5:46 pm Post Subject: fence replacement |
[HELP PLEASE]
MY FENCE[WOODEN] CAME DOWN IN RECENT GALES.
QUESTION.
THE VERTICAL POSTS BROKE OFF AT GROUND LEVEL
I HAVE NO IDEA HOW DEEP THESE GO. HOW CAN I OR WHAT IS THE BEST WAY [EASIEST]TO REMOVE WOOD AND REPLACE UPRIGHTS? THEY ARE IN
CONCRETE AND RUN ALONG A LOW RETAINING WALL IF I HAVE TO BREAK OUT THE POST ENDS WITH A DRILL AND DISTURB THE BRICKWORK WILL THIS PROVE HARD TO REMEDY .
ANY IDEAS AND SUGGESTIONS .
_____________________________
lynda, moderator
please note forum rule 6 |
masona
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
Posted: Tue Dec 05, 2006 6:38 pm Post Subject: |
Might be easier to start fresh post holes approximately in the middle of the ex-panel and put in a half panel to make up for it, there are normally about 24" deep in the ground. Also it would be a good idea to have a difference fence panel design to allow the wind to go through the fence panel instead of the force wind bending it unless the post hole isn't deep enough. If you want to use the same post hole then a small kango breaker or SDS drill to break it out,
example, many difference type
Just re-read it, not sure where your retaining wall is, on the side or on the top of the wall? __________________ Always judge a man by the way he treats someone who is of no use to him |
