TanC
Joined: 07 Dec 2006 Posts: 1 Location: Sussex, United Kingdom Thanked: 0 times
Posted: Thu Dec 07, 2006 11:31 pm Post Subject: Help!! Weak hot water and want a good shower! |
I need help deciding which shower would be best to fit in my bathroom. We have weak hot water pressure and have always had a mixer shower which is linked to the bath taps. I have very good cold water pressure and a cold water tank in the loft. The hot water comes from a cylinder in the airing cupboard which I think is very old. It is a Hercal Coil Indirect cylinder - Double feed and capacity 93 litres if that helps. (It means nothing to me!!)
What is the easiest way to get a descent shower?? Do I install a pump in the airing cupboard and get a thermostatic (we have ripped the tiles off so tapping in pipes would be fine at the mo. OR Do I get an electric shower. Looking for the least hassel and least expensive route (don't mind spending on the shower fittings though!) |
sime10
Joined: 19 Oct 2006 Posts: 728 Location: Cardiff, United Kingdom Thanked: 0 times
Posted: Thu Dec 07, 2006 11:36 pm Post Subject: |
power shower is ok but don't give you much apart from that noisy pump,
Electric shoer can be worse take your pick  __________________ You live to learn and Learn to live |
