prob
4 Dec 2006
Cheshire
seems to be air in central heating ,could leaking rad valves draw air in when working.
Much more often it is gas produced when the steel radiators corrode.
Has the system been clean and refilled with inhibitor?
What colour is the water that squirts out when you bleed the rads?
Is it a sealed system or has it got a feed and expansion tank in the loft?
system has been drained and refilled water comes out pretty clean it has feed and an expansion tank in attic
gordongas said:
yes if the system is a negative, ( pump sucking water round)
how do you find if is a negative ,how would this make a difference
you need to know where the cold feed enters in relation to the pump.
Where's the pump, logically speaking.
Does the flow from the boiler go
boiler> Vent> feed pipe > pump > motorised valve(s)
, or what?
MAybe the pump's on the return???
Open an upstairs radiator air vent with the pump running, does it suck air in or let water out.
That is the difference, one you cannot bleed with the pump running. :LOL:
, or what?
it comes from boiler tees off to vent then tees from feed to pump then into three way vavle splits one warm water one goes through imm tank
it still vents water through bleed screw
the feed from tank in attic is just before the pump which flows into 3 way valve
