DIYnot
Local | Network
   DIYnot > Forums
Local | Network
repair badly cut holes for spotlights
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
blade1212
from United Kingdom
PostPosted: Thu Dec 21, 2006 2:30 pm Reply with quote
I hope somone can advise me.
I have to finish off a shower room ceiling but one of the of the spotlight holes (72mm diameter) was badly positioned (next to a wooden joist). The result is that I've had to move the 72mm holes into a free postition - the centre of the new hole is about 20mm away from the badly positioned one (but overlapping - hope u can visualise what I mean).
The quesiton is how do you recommend I repair the plaster around the hole to bring it back to a smooth looking 72mm hole ?
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 221 times
PostPosted: Thu Dec 21, 2006 2:46 pm Reply with quote
You can build it up with Polyifilla etc & repaint.
Back to top
 Alert Moderators
blade1212
from United Kingdom
PostPosted: Thu Dec 21, 2006 4:05 pm Reply with quote
Thanks for the quick answer. I'll give it a go.
Back to top
 Alert Moderators
PilotPete
from United Kingdom
PostPosted: Thu Dec 21, 2006 9:13 pm Reply with quote
If it is a plasterboard ceiling, cut another piece of plasterboard to the 'moon shape' that you require as a fillet and then stick it into place with a bit of support behind to the top side of the ceiling (Gripfill is good). Fill in the cracks with polyfilla, sand as required and job done.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
How many recessed spotlights to have? 6 1100 Wed Mar 22, 2006 12:25 pm
Measuring spotlights for later drill. 5 360 Tue Mar 07, 2006 11:08 am
Can paint react badly with previous paint and cause a rancid 4 520 Sun Apr 20, 2008 5:06 pm
Lining paper badly joined 3 640 Thu Jul 19, 2007 9:43 pm
Skirting board paint badly painted on to wall 3 120 Fri Jun 20, 2014 5:18 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
