DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bosch dishwasher won't turn off!
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
Tudordoc
from United Kingdom
PostPosted: Wed Jan 03, 2007 9:30 pm Reply with quote
I have a Bosch SGV 4313GB dishwasher. This morning I found that the dishwasher was still running from the night before. I opened the door and it still carried on trying to drain. If I push the power button on the door it stops but as soon as I push it again it starts trying to drain instead on going to being ready to start.. I put water through the drain (with the door open) and it gets drained out immediately.
Obviusly something is stuck - but what. Is it curable?
Help please!
TudorDoc
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Wed Jan 03, 2007 10:29 pm Reply with quote
Base is flooded and anti flood device activated.
There are a few posts detailing this. Have a look at some of the Bosch dishwasher posts. icon_smile.gif
Back to top
 Alert Moderators
Tudordoc
from United Kingdom
PostPosted: Wed Jan 03, 2007 11:10 pm Reply with quote
Thanks for the prompt reply.
I took the front panels off. I could not find a reservoir to empty. I did see a vertical red piece of plastic that runs towards upwards but is connected to something near the base of the door. I gave this a wiggle. Put back the panels and the problem seems to be cured - so far. There is no water under the machine. Maybe it is just old and the red thing got stuck.
Anyhow have now run one cycle. Fingers crossed
TudorDoc
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Thu Jan 04, 2007 6:45 am Reply with quote
The red thing is part of the anti flood device. Water in the base lifts the polystyrene block which in turn lifts the red arm and this activates a micro switch.
Back to top
 Alert Moderators
Tudordoc
from United Kingdom
PostPosted: Tue Jan 09, 2007 10:31 pm Reply with quote
After running fine for a week, same problem. Owing to the built in design the anti-flood devide is hard to see and get at. Is this something an engineer could replace or do I give up?
TudorDoc
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Tue Jan 09, 2007 10:35 pm Reply with quote
Bit of a pig of a machine to strip down to be honest.
If the anti flood is being activated you've either got a leak or overfoaming is taking place.
Finish tablets are notorious for it as is using rinse aid along with any 3,4,5 in 1 tablets.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Bosch dishwasher SHV55M03GB/40 spraybars don't turn 16 5800 Wed Nov 10, 2010 11:36 pm
Bosch Exxcel Washing Machine doesn't turn drum 7 600 Thu Aug 05, 2010 10:23 am
Bosch W/M WFX3267GB/10 Motor pulsates but does not turn. 5 160 Mon Mar 07, 2011 12:21 pm
Turn off the end of cycle alarm for Bosch WAQ283S0GB? 9 15740 Thu Oct 11, 2012 11:09 pm
Bosch Exxcel 1200 Express washing machine drum won't turn 2 40 Wed Feb 29, 2012 9:44 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
