I installed a new shower in August. Due to lack of pressure i fitted a salamander pump in the loft at the base of the hot water tank as per instructions. Pipe work then runs along the loft before dropping down into the cavity walls to join home of amber concealed mixer shower. This worked fine for a few months then became hit and miss as to wether any water would come out when the shower was turned on. It has now ceased completely. I have changed the pump thinking that was busted but the problem persists. When disconnected in the loft water flows as it should in the pipe work and pump kicks in, so problem seems to be with the mixer unit. Any ideas? Talked to manufacturer and they seem to think it could be the non return valves. Would both of these go at once?
Please help before i hack a hole in the newly tiled walls and the missus plays hell
