how to cut moasic mable tile
12 Mar 2004
fitted new kitchen, spent alot of money on marble moasic tiles which come on a sheet. Booked up a professional to fit them!! Waited 6 weeks, now told him not to bother in a polite way! I need advice on how to cut the small tiles. I have used normal ceramic tile before and that was fine. They are on sheet 300 x 300 each tile is 30 x 30 x 10mm thick ish. Will I have to purchase an electrical tile cutter, will it cut marble? :confused: :confused:
Just an example of many type for tile cutting saw bench,must get one with water tank for cooling the blade.Take extra care when cutting, as the tile is only small.Maybe you could make 150mm wide piece of flat wood with a square slot on the side edge for the tile to slip in for cutting safety.
Yes , I was thinking about for the small tile size 30mm x 30mm,the blade will be too near the hand.
