Help with landis & gyr RWB2 mechanical programmer
20 Jan 2007
Hi there
This link http://cgi.ebay.co.uk/LANDIS-GYR-RW...QcategoryZ3191QQcmdZViewItem#ebayphotohosting shows an image of my programmer. Basically, I don't understand what the various switches do and have been unable to make the heating come on in my flat. (Just moved in) Can anyone help please? I know its a mechanical switch but not sure how to get heating on!
(Thermostat has been turned up and programmer has power as red lights are on, and radiators are open, but still nothing works)
Thanks!
if the lights r on on hw & ch then the fault is probably not with the clock, is the hot water getting hot ? depending what type of system u have it could be the pump failed, or pump spindle stuck or a zone valve fault. more info needed . picure of pump/boiler/ cylinder.
I switched on the immersion heater in the boiler (mistakenly thought it was the hot water switch for the central heating) and so I have hot water. BUT now can't tell if the boiler/ rest of the system is producing hot water. I have switched it off now (i.e the immersion heater) and will wait and see
In the meantime, how do I investigate the pumps/ valves? Thanks for such a quick reply by the way!
