DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Hagar MT132 - can I have a 8.5kW shower?
This topic originated from the How to page called Fitting an electric shower
Click here to return to the page called Fitting an electric shower.
Goto page 1, 2, 3  Next
  View previous topic :: View next topic
Author Message
sarahmarie
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 21, 2007 3:58 pm    Post Subject:
Reply with quote Thanks
I currently have a 7.2kW shower which is connected to a Hagar MT132 next to the fuse box. Can I have an 8.5kW shower? My understanding is that I cannot because it is 32amp and an 8.5kW shower needs 40amp. But I want to check this before I have the fitting changed and a new wire pulled through. Thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 24 times
PostPosted: Sun Jan 21, 2007 4:13 pm    Post Subject:
Next to the fuse box? Could you post a picture on here? Is it in a seperate white enclosure? If so it will be easy to change for one of a higher rating.
an 8.5kw shower requires 36 amps, so you'd have to up the MCB rating, which is an easy job. Your electrician will advise.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sun Jan 21, 2007 4:16 pm    Post Subject:
I wouldn't change an MCB until I have verified the cable is adequate to take the additional load too. Like Crafty says, consult a local spark as this work is notifiable to LABC under part P of the building regs.
Back to top
 Alert Moderators
sarahmarie
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 21, 2007 4:49 pm    Post Subject:
Thanks to both of you for your replies. I was trying to find out whether replacing my shower was a job I was allowed to do myself - which it obviously isn't. Annoying, because elecitricians are so busy!
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sun Jan 21, 2007 4:53 pm    Post Subject:
Legally you are allowed to do the work yourself if you notify your local area building control and pay their fee before you do it. The fee you pay to LABC may be more than the cost of a spark though.
Back to top
 Alert Moderators
sarahmarie
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 21, 2007 4:57 pm    Post Subject:
Spark123,
If I got an electrician to change the MCB unit and pull through a new wire (assuming the current one is no good) and fit a new shower (but I bought the shower myself) what sort of sum of money would I be looking at?
(I realise you can't give me an exact figure, I just want an idea of what money I need ready for the job.)
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 24 times
PostPosted: Sun Jan 21, 2007 7:08 pm    Post Subject:
MCB swap and test - 30 mins
shower swap and test - 30 mins
cable - depends on the route. run it yourself, then the electrician just has to connect up. Make sure he can still see its route when he arrives.
He will have to connect the wire both ends and to the switch, make good, test and inspect, allow up to 90 minutes @ between £25 and £35 per hour, though this varies around the country and from spark to spark, and the electrician may add on bits for the distance travelled, grief factor when using customer-supplied stuff, and other things we cannot see.
Back to top
 Alert Moderators
sarahmarie
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 21, 2007 7:50 pm    Post Subject:
Financially I think it makes sense to get someone to do it for me. Thanks for your help. icon_surprised.gif)
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Sun Jan 21, 2007 9:49 pm    Post Subject:
I guess you have never swapped a shower then.
More like 2 to 6 hours.
__________________
I downlights
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 24 times
PostPosted: Mon Jan 22, 2007 2:39 pm    Post Subject:
I meant simply disconnecting the old one, mounting and connecting the new one, excluding plumbing. Just the work at the shower itself, not the switch or running cable . . . Maybe an hour would be a more appropriate guess. What have I missed RF?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Mon Jan 22, 2007 5:48 pm    Post Subject:
Driving to the job, nip to wholesalers for parts, upgrade bonding etc, testing, replace the shower, fill in the paper work, load car, cup of tea, bait time, leave job and go to pub.
Back to top
 Alert Moderators
ELZ4742
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 22, 2007 5:57 pm    Post Subject:
also full equipotential bonding, gas and water is now required.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Mon Jan 22, 2007 6:02 pm    Post Subject:
I could have sworn I mentioned upgrade bonding etc. Although it best practice to have a shower protected by RCD, it is not a requirement of BS7671 to do it. It is only mandatory if the manufacturer specifies it. This is the sort of thing the spark would advise on when attending the job.
Back to top
 Alert Moderators
ELZ4742
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 22, 2007 6:08 pm    Post Subject:
rubbish, read your regs.
Zone 1
Requires electrical products to be IPX4 or better, or SELV with the transformer located in zone 3 or beyond. If the fitting is 240v, a 30mA RCD must be used to protect the circuit.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Mon Jan 22, 2007 6:13 pm    Post Subject:
Zone 1
I don't think so, what does 601-09-02 say?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 3
Jump to:
Hagar Ouch! 3 440 Sat Jun 14, 2008 8:36 pm
electric shower safety/legality? 21 1040 Sun Jan 06, 2008 3:07 pm
Sockets in loft for shower pumps 9 420 Sun Jan 06, 2008 11:11 am
new shower mcb 21 880 Fri Jan 04, 2008 2:33 pm
Shower switch - how hot? 7 280 Sun Jan 06, 2008 7:20 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
