DIYnot
Local | Network
   DIYnot > Forums
Local | Network
moving a cooker socket
Author Message
dazshaz
from United Kingdom
PostPosted: Wed Jan 24, 2007 11:50 pm Reply with quote
hi there
can i be possible to move a cooker socket?
ive put new cupboards and worktops in, but the only place i could put move hood"i have found the cooker switch will be in the way of the hob.what i mean is when i will be cooking the steam will head towards the socket!!!
is this a problem?? or can the socket cope with steam
what can i use to join the wire if i need to move it??
i will have to dig the wall out to ake a new hole for the socket, this wll also be a problem, because its concrete
daz
please help
Back to top
 Alert Moderators
CookyMan9999
from United Kingdom
PostPosted: Wed Jan 24, 2007 11:53 pm Reply with quote
even if you were to join it the join in the cable should still be accessible which would still present the same problem as before. Is it the cooker switch or a socket?
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Wed Jan 24, 2007 11:54 pm Reply with quote
Your not very clear. Are you saying the cooker switch will be directly above the cooker? icon_eek.gif This is wrong. You need to move the switch so it sits about 20cm horizontally to the side of the cooker.
The wall might be concrete, but i bet its got a plaster finish. Plaster comes off easily if you pull at the cable. icon_wink.gif
Back to top
 Alert Moderators
CookyMan9999
from United Kingdom
PostPosted: Wed Jan 24, 2007 11:56 pm Reply with quote
Quote:
"Plaster comes off easily if you pull at the cable."
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 457 times
PostPosted: Thu Jan 25, 2007 8:29 am Reply with quote
Not if the render underneath the skim is cement...
Back to top
 Alert Moderators
dazshaz
from United Kingdom
PostPosted: Thu Jan 25, 2007 8:58 am Reply with quote
i know this is wrong "thats why im asking about moving it!
is the a way i can connect a new piece of wire behind the cooker switch"switch on the wall with cooker and 13 amp switch"
i know it can be done on normal plugs with connectors,but with this wire to the cooker being thicker etc im not sure what to use.
the wall has about 2-3 plaster on a concrete wall, so i will find it hard to move the box, but il do my best
daz
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Moving a cooker 4 360 Sat Dec 29, 2007 1:30 pm
moving an electric cooker 7 760 Sat Dec 22, 2007 9:31 am
Moving Cooker Isolation Switch 4 160 Tue Jul 01, 2014 8:02 pm
Moving Cooker Switch 15 180 Mon Jan 02, 2012 10:55 pm
Moving Cooker 11 640 Mon May 02, 2005 5:40 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
