DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Best Type of Shower - Power Vs Cost!
This topic originated from the How to page called Choosing a shower
Click here to return to the page called Choosing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
JTaylorUK
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 11, 2007 5:03 pm    Post Subject:
Reply with quote Thanks
I'm just about to rip my bathroom out and install a new one, including a shower. I've spent the weekend looking on the screwfix website and am now more confused than ever!!
I live in an all electric house, so no boiler, just a large HW tank right next to the bathroom, and a CW tank in the loft (1 floor above).
I want a shower that really pumps through the water (might wake me up in the mornings!) and was thinking about a seperate pump installed in the cupboard with the HW tank (I can make simple connections to both H and C pipes there), then connect to a standalone shower.
So, questions:-
1. Will a cheap Salamander 1.5bar pump give adequate grunt, or do I need a bigger one?
2. What type of shower works best with a pump (manual mixer, thermostatic mixer, etc) as the prices seem to alter hugely!!
3. Is this the best system for me, or have I completely confused myself.
4. If the pump is a good idea, can I simply power it up by taking a spur from the immersion, or does it need to be powered direct from the fuseboard.
5. I take it shower pumps operate by demand, ie. they fire up automatically when you turn the shower on?
Ok enough questions for now, please set me straight if you can, before I have a nervous breakdown!!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon Feb 12, 2007 3:12 am    Post Subject:
Re: Best Type of Shower - Power Vs Cost!
1.5 bar is fine, but a cheap pump will be a false economy.
That's a non question - the issue is whether or not you want thermostatic control or to have to fiddle with the temperature knob yourself.
If you already have stored hot and cold water then a pumped thermostatic shower is your best option.
Neither. Heavy load appliances that are on for long periods should have their own dedicated circuit, but a pump can be wired to a spur from your ring circuit (aka ring final circuit).
They don't "fire up", but they do switch on when flow to the shower is detected. If your head of water is inadequate for a positive pressure pump, then there are alternatives, e.g. a negative pressure pump.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Cost of replacing a power shower 5 280 Wed Dec 03, 2008 9:21 pm
Power Flush - Indication of Cost Please 52 1400 Wed Oct 14, 2009 9:53 pm
Leaking shower...approx cost to fix? 12 1640 Sun Jan 20, 2008 12:56 pm
cost of full install of shower from scratch 8 1120 Wed Apr 13, 2005 11:37 pm
Cost of installing shower 2 1560 Mon Apr 24, 2006 6:23 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
