Revelation
Joined: 12 Feb 2007 Posts: 2 Location: London, United Kingdom Thanked: 0 times
Posted: Mon Feb 12, 2007 3:17 pm Post Subject: Do I need a flange? |
Hi guys,
I recently installed a Salamander pump to feed my shower. I pretty much followed all the instructions to a tee, but have not bothered installing a flange.
I was wondering, since the pump is only feeding the shower and not the whole flat, do I still need the flange installed?
What happens if I don\\\'t install a flange? :s
Thanks for any help!! |
ChrisR
Joined: 24 Jul 2003 Posts: 18663 Location: London, United Kingdom Thanked: 62 times
Posted: Mon Feb 12, 2007 6:29 pm Post Subject: |
You run the risk that
a) it won't work
b) you damage the pump |
Revelation
Posted: Mon Feb 12, 2007 9:29 pm Post Subject: |
Thanks ChrisR,
It was actually working great until today - the hot water suddenly lost pressure, so I am assuming it was due to the flange as this affects the hot water (right?).
Can you explain exactly what task a flange is meant to perform? Am I right in guessing its like when you let water flow out of a water bottle, it can be speeded up made to flow much quicker if a hole is put into the top of the bottle.
Thanks guys. |
Softus
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
ChrisR
Posted: Mon Aug 06, 2007 12:32 pm Post Subject: |
One risk is that you suck air down the vent pipe. Then you don't get hot water, and the pump overheats and leaks thereafter. |
