I am replacing the cam belt on my Vectra. My problem is that there is not enough slack in the belt to get it over all the sprockets and pulleys.
I am sure the tensioner is in the correct position. i.e. putting the least tension on the belt. Also that the belt routing is correct.
I have compared the new belt and replacement tensioner and idler pulleys with the old items. It all looks identical. I am using a PowerGrip kit which is correct for the Z18XE engine.
The crank and cam shafts are in the correct position.
I can almost get the belt on but it is too tight for me to slide it over the edge of the last pulley and into position. I am only doing it by hand. I have not used any tool to try to put the belt on for fear of damaging the belt or pulley.
Vectra 1.8 ecotec. 2001 model. Any help or advice appreciated.
