DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Switch for floor lights
This topic originated from the How to page called Adding a new light and switch
Click here to return to the page called Adding a new light and switch.
  View previous topic :: View next topic
Author Message
sb258
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 24, 2007 2:27 pm    Post Subject:
Reply with quote Thanks
I am writing the spec for rewiring of my new flat - to be done by a qualified electrician.
In my front room I plan to have 2 ceiling lights and 2 floor lamps for lighting.
I would however like to control the floor lamps with a normal wall dimmer switch.
Am curious as to how this might be done.
Would there be a separate floor run radial circuit with a channel running up to the light switch box to join cables running down from the ceiling lighting circuit?
Also, what sort of wall socket should be used to plug the lamps into?
In another flat I have seen round pin plugs used to designate that the socket is not part of the ring main but this can't be allowed in the new regulations?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 24 times
PostPosted: Sat Feb 24, 2007 2:40 pm    Post Subject:
5 amp round pin plugs are fine. Cabled up to the ceiling, and wired to the lighting circuit as normal.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat Feb 24, 2007 8:28 pm    Post Subject:
2A 3 round pin sockets are what I use.
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Floor lights on lighting or mains circuit? 3 180 Sat Jul 11, 2009 3:07 pm
Outdoor "floor" lights in Flagged patio 16 3920 Mon Jul 30, 2007 1:59 pm
Puzzling problem with 2nd floor lights 3 340 Mon Oct 03, 2005 10:15 am
Cables under floor boards 9 620 Fri Jan 12, 2007 10:58 am
Routing 32A ring main through floor joists 8 720 Fri Feb 23, 2007 3:31 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
