DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Leaking shower
This topic originated from the How to page called Choosing a shower
Click here to return to the page called Choosing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
DaveyBoy1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 27, 2007 9:43 am    Post Subject:
Leaking shower
Reply with quote Thanks
Hi there,
New to the forum for the simple reason that my shower is leaking I\\\'m worried and I need advise so I don\\\'t electrocute myself!
I\\\'m not sure of specs and the like yet but I\\\'ll have a closer look tonight and check up on whats actually happening.
I was having a shower today and noticed that in addition to the hot water comming out of the head I was getting a dribble of cold water running down onto my leg.
On further inspection I found it was running out of the shower casing itself. Needless to say I turned the shower off straight away.
Why would there be water running out of the main body of the shower? I think its a Mira. It has a pipe running into it with an on off valve for the water. One control knob on the bottom for temperature and one on the top to turn the shower on and off.
Can anyone help me with this, why is it leaking?
I\\\'ll have a look the night and maybe take some pics to see if anyone can help out.
Cheers
Davey
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
DaveyBoy1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 27, 2007 10:58 am    Post Subject:
BUMP
Seven looks and no ideas????
Back to top
 Alert Moderators
denso13
from United Kingdom
Thanked: 2 times
PostPosted: Tue Feb 27, 2007 11:09 am    Post Subject:
You'll have to have a closer look inside the unit. Could be coming from lots of places.
Back to top
 Alert Moderators
DaveyBoy1
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 27, 2007 5:30 pm    Post Subject:
More Info
Right some more details:
Manufacturer: Neptune showers
Model: Solo
Power rating: ?
The leak seems to be coming from behind the on/off switch casing and is spraying/dripping down the remaining length of the unit.
Is there a way to fix it/replace it or do i need to buy a whole new unit?
If so is there a more powerful model available as an upgrade that has the same attatchment points to make it easy for me to fit.
I have taken some pics but don't know how to attatch them?
Any help greatfully received.
Cheers
Dave
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 15 times
PostPosted: Tue Feb 27, 2007 8:34 pm    Post Subject:
It sounds like new shower time. You'll be lucky to get one with identical fitting points, you'll probqably have to do a little bit of work but nothing too drastic.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
mystery leaking shower 4 260 Tue Feb 19, 2008 2:49 pm
Triton Power Shower Leaking after Central Heating Install??? 5 460 Mon Feb 18, 2008 7:16 am
Leaking Shower.... 2 120 Sat May 23, 2009 2:00 pm
Water leaking from nut on bath/shower mixer 5 400 Tue May 31, 2005 7:01 pm
Leaking quadrant shower cubicle - Merlyn/Black Box 2 200 Sun Apr 26, 2009 10:24 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
