DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Flushing toilet causes prolonged vibration / noise in pipes
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
vverman
from United Kingdom
PostPosted: Fri Apr 13, 2007 3:30 pm Reply with quote
I hope someone can advise. I'm using this website for the first time. We have just moved into our first home.
I'll follow the format I have seen some others use:
1) Boiler
STRATA 38 wall mounted ultra high efficiency condensing boiler. The booklet says 'Model 38 boiler & the 38/46 Combi'
2) Problem
There are 3 toilets in the house (1 downstairs, one in main bathroom and one to the en-suite). When the toilet is flushed in the main bathroom, the pipes make a long , loud prolonged noise. When turning on the basin tap I noticed that the noise stops but as soon as I turn of the tap, the pipe vibrations/noise continues (in total when flushing the noise lasts for 30 seconds or so). Notably this happens from the main toilet when flushing but also when using the basin in the en-suite there is some noise although not as bad. A friend suggested bleeding all radiators, from upstairs, going downstairs (as the boiler is in the kitchen). I did this last night but hasn't made much difference. In the main bathroom, when flushing the toilet the loud noise from the pipes seems to be contained within that bathroom, can feel vibration under the floor.
We really need to address this quickly, I am obviously concerned. Prior to buying the house we had a plumber check this out, he must have just turned on a few taps and confirmed that there wasn't a problem. Flushing the toilet is causing this moreso. Before I call out another plumber, would appreciate your feedack and advice. Thank you in advance.
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 200 times
PostPosted: Fri Apr 13, 2007 3:53 pm Reply with quote
noise is most likely from a valve on the mains water or the pipe could be loose under the floor and vibrating under load......could be the toilet but i would try to move the mains stopcock fully open as a first guess as it may just be the blade inside it vibrating.....worth a try
Back to top
 Alert Moderators
weareleeds
from United Kingdom
Thanked: 2 times
PostPosted: Fri Apr 13, 2007 4:46 pm Reply with quote
May also be faulty ballcock or float valve on toilet
Back to top
 Alert Moderators
wonderb0y
from United Kingdom
Thanked: 1 time
PostPosted: Fri Apr 13, 2007 4:59 pm Reply with quote
i'd go with above try the float valve first
Back to top
 Alert Moderators
vverman
from United Kingdom
PostPosted: Sun Apr 15, 2007 8:58 pm Reply with quote
Thank you all for your feedback, I will revert later in the week! V.
Back to top
 Alert Moderators
BoxBasher
from United Kingdom
Thanked: 1 time
PostPosted: Sun Apr 15, 2007 10:32 pm Reply with quote
And then back one quarter turn so it doesn't seize in the open position.
Likely culprit
Back to top
 Alert Moderators
vverman
from United Kingdom
PostPosted: Mon Apr 16, 2007 12:10 pm Reply with quote
nickso / box - thanks very much for the info.
I hope one of these options will rectify it...would I be able to email you at a person email address to understand things a little better (rather than bore others)! Thanks.
Back to top
 Alert Moderators
BoxBasher
from United Kingdom
Thanked: 1 time
PostPosted: Mon Apr 16, 2007 12:28 pm Reply with quote
Feel free to keep it public...
... that way others can benefit from the info and add their own opinions/experiences.
Back to top
 Alert Moderators
tomtom82
from United Kingdom
PostPosted: Mon Apr 16, 2007 7:40 pm Reply with quote
n.b. im not a plumber but i had a very simmilar problem with my new toilet causing all the pipeing/boiler to vibrate very loudly.
the plumber eventually found a piece of grit from the new installation in the toilet mechanism which was causing tap slam or water hammer or what ever he called it. good news it was very easy to fix!
Back to top
 Alert Moderators
vverman
from United Kingdom
PostPosted: Tue Apr 17, 2007 11:14 am Reply with quote
tomtom, Great tip, thanks very much. What I’ll do is shut the stop valve to the toilet in question and then give it a flush to see if the noise persists. If it doesn’t, I believe this indicates that the ballcock (fill valve) is faulty and then I will need to replace this. This is according to the replies I have received so far and from further searches for information on-line. If there is any such grit visible I’ll now clean this up and open up the stop valve and try flushing again to see if the pipes start vibrating and humming again. If they do, then I hope it’s just the ballcock / fill valve.
If I do need to replace the ballcock / fillvalve, can anyone suggest the best place to buy these? From what I’ve read it’s important to get exactly the same make/type (apparently it should stated on the fill valve itself). I would probably try Wickes / B&Q…if someone suggests another large store is better choice first off, please advise.
Thanks again.
Back to top
 Alert Moderators
BoxBasher
from United Kingdom
Thanked: 1 time
PostPosted: Tue Apr 17, 2007 1:16 pm Reply with quote
Try a proper plumbers merchant as opposed to a shed. They will be able to give you good advice.
Getting an exact match doesn't matter all that much. Just make sure that if it's a side entry you get side entry, bottom entry ditto.
Back to top
 Alert Moderators
vverman
from United Kingdom
PostPosted: Tue Apr 17, 2007 2:02 pm Reply with quote
Box, thanks for the reply. Based on the above comments, should I purchase both a ‘ballcock’ and ‘float valve’ (or are they part of the same thing?). I’m getting a little confused with the terminology.
Is ‘float-valve’ the same as ‘fill valve’?
Isn’t ballcock just another way of referring to the ‘fill valve’?
Perhaps I’m confusing myself …based on the problem I’ve mentioned and the advice given by others please confirm which part(s) I should be purchasing…
Thank you again.
Back to top
 Alert Moderators
lewisv6
from United Kingdom
PostPosted: Fri Jul 31, 2009 3:31 pm Reply with quote
always go for the ballcock first water inlet gear turn off supply of water dismantle it and clean reassemble put water back on if still there replace it easy and cheap to do
Back to top
 Alert Moderators
doitall
from United Kingdom
Thanked: 1098 times
PostPosted: Fri Jul 31, 2009 3:40 pm Reply with quote
Just get the caretaker, maintenance, Gardener to change or service the plastic ballvalve and the problem will be no more. icon_rolleyes.gif
Back to top
 Alert Moderators
lagunaglen
from United Kingdom
Thanked: 2 times
PostPosted: Fri Jul 31, 2009 4:23 pm Reply with quote
ditto doitall,just disassemble the inlet valve,clean and reassemble ,often if there has been any work on the mains in the street it can cause sand to enter and cause minor problems.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Prolonged buzzing noise in rising main when tank nearly full 5 80 Tue Oct 04, 2011 11:16 am
vibration noise transmitting through heating pipes 2 880 Thu Dec 11, 2008 11:47 am
vibration in water pipes after replacing a toilet valve 2 560 Wed Jun 02, 2010 12:51 pm
Cold Water feed Electric Shower and vibration/noise 3 1260 Sun Jul 31, 2005 2:34 pm
Radiator Vibration noise 14 13120 Tue Feb 01, 2005 5:46 pm
DIYnot
