DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
rewireable fuses
This topic originated from the How to page called Changing a fuse on the consumer unit
Click here to return to the page called Changing a fuse on the consumer unit.
  View previous topic :: View next topic
Author Message
lennydavey
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 12, 2007 1:10 pm    Post Subject:
rewireable fuses
Reply with quote Thanks
I need to replace an old ceramic 4 pin rewireable 30 amp fuse, can i purchase one without having to replace the whole fusebox
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat May 12, 2007 1:13 pm    Post Subject:
Which manufacturer, model etc? Have you dropped it? Can you post a photo?
http://www.diynot.com/forums/viewtopic.php?t=73320
Back to top
 Alert Moderators
lennydavey
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 12, 2007 1:23 pm    Post Subject:
Its an mem. Just moved into a new house and the shower was wired into a 5 amp fuse with 15amp wire in it, but kept blowing the fuse wire. and have been told i need to replace it with the correct amp fuse and wire.
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Sat May 12, 2007 1:31 pm    Post Subject:
What sort of shower? How many kilowatts?Cable size?RCD protected?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat May 12, 2007 1:41 pm    Post Subject:
Photo?
Sounds like a bit of bodging has been going on, one thing for sure you should not replace a fuse with anything bigger without ensuring the existing cable and arrangements are suitable for the additional load.
I think your best bet will be to get a qualified electrician in to take a look.
Back to top
 Alert Moderators
passerv
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 12, 2007 3:16 pm    Post Subject:
30 amp fuse, then 5amp fuse, with 15amp wire,
then replace with the correct fuse and wire????
I'm a bit confused
need more coffee.
penny dropped... fuse carrier
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat May 12, 2007 7:51 pm    Post Subject:
Many fuses are sized and can only safely accept a maximum size of fusewire.
What size is the shower?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Sat May 12, 2007 8:29 pm    Post Subject:
Just had a look through the achives, and came up with these fuse boxes with ceramic fuses.
Does your fuse box look like any of these?
The first two are MEM, the third is made by 'falkes' (No I havn't either)
__________________
I downlights
Back to top
 Alert Moderators
mdbalson
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 14, 2007 12:42 pm    Post Subject:
Or does it look like this one icon_question.gif Which is a MEM Memera 3
http://i167.photobucket.com/albums/u125/mdbalson/P3160021.jpg
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon May 14, 2007 12:57 pm    Post Subject:
RF, the second "MEM" looks quite a common type, I think I've converted those to Cartidge fuses in the past (MEM used to sell a dark brown cartridge holder that fitted it to replace the porcelain rewirable one)
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Mon May 14, 2007 6:01 pm    Post Subject:
John, This is the fusebox pictured above with the cover on.
__________________
I downlights
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Mon May 14, 2007 6:28 pm    Post Subject:
JohnD Here is the other switch fuse with the cover on.
Are you sitting down?
__________________
I downlights
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon May 14, 2007 6:47 pm    Post Subject:
very neat.
Basement of a block of flats, is it?
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Mon May 14, 2007 6:51 pm    Post Subject:
Its a 5 storey office block. One switch fuse for each office. Each floor has two offices.
__________________
I downlights
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon May 14, 2007 6:52 pm    Post Subject:
Lad!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Are Wylex C. U.'s with rewireable fuses still legal? 6 360 Sat May 30, 2009 8:31 pm
rewireable fuses 7 760 Wed Feb 14, 2007 9:25 pm
rewireable main fuses? 2 520 Tue Jun 20, 2006 9:21 pm
Old MEM 30A Rewireable Fuse / Shower 8 2120 Wed Oct 05, 2005 11:12 pm
9.5kw shower 30 amp rewireable fuse 4 400 Fri Aug 28, 2009 2:01 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
