Hi\\\'m having problems with my com-bi boiler it seems to work fine hw but when in ch mode boiler will not always fire up ,some times I switch the supply to the boiler off and on and the boiler fires up and stays on until I turn room stat to satisfied and then it switches off . Then I switch room stat on to call for heat and you can hear a relay clicking in but boiler still won\\\'t fire up. then with the room stat still calling for heat I turn the hot water on from the tap and boiler fires up and won\\\'t go off until room stat is turned to satisfied. Any advice would be very much appreciated. Many thanks Simon.
