The machine keeps filling and then I get the flashing pre-wash light - what is supposed to turn off the water, is it timed or is there a sensor? Can I get a service manual for one of these?
Thanks breezer
I've disconnected the tube to the pressure chamber - I guess as the drum fills up the pressure increases - I tried blowing into the pipe as the machine filled up and this did start the drum rotating...but what to check now - I guess the switch could be faulty or the pressure isn't building up sufficiently. I've sealed the tube back up as best I could but the machine just keeps filling until the prewash light flashes...perhaps I should attach a bicycle pump to the end of the tube ... or just buy another washing machine.
