Dan2007
Joined: 18 May 2007 Posts: 1 Location: London, United Kingdom Thanked: 0 times
Posted: Fri May 18, 2007 12:19 pm Post Subject: Low Water Pressure |
Hi everyone,
I have just bought a little one bedroom 4th floor flat, which has an ancient hot water cylinder / water storage tank / boiler setup however the water pressure is still too low to have a shower in.
Is there any way I can replace the existing system with only a boiler and increase the water pressure sufficiently?
Thanks very much |
fumb
Joined: 08 Jan 2007 Posts: 77 Location: Bournemouth, United Kingdom Thanked: 0 times
Posted: Fri May 18, 2007 12:51 pm Post Subject: |
Check the pressure and flowrate at the kitchen tap. If it's good then a combi might be the way forward |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Fri May 18, 2007 2:07 pm Post Subject: |
or a shower pump will cost you about £1,000 less. |
BoxBasher
Joined: 01 Nov 2006 Posts: 998 Location: United Kingdom Thanked: 0 times
Posted: Fri May 18, 2007 2:30 pm Post Subject: |
Or an electric shower with built in pump like the Triton T80si pumped will only require a tank with 8cm head. |
