DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Hot water for shower
This topic originated from the How to page called Choosing a shower
Click here to return to the page called Choosing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
shultz
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 03, 2007 2:16 pm    Post Subject:
Reply with quote Thanks
I have a conventional gravity hot water system and hot & cold water supplied from the same tank. I am told that one can fit a valve to the hot outlet from the cylinder so that the shower supply will not be affected by other taps opening. I think the valve is called a Surrey Valve. Is this correct and is the name correct? I have been unable to find such a valve on plumbing supplies websites.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun Jun 03, 2007 2:25 pm    Post Subject:
Yes, the surrey flange fitting replaces the 22mm outlet connector on top of the cylinder, then you have 2 22mm outlets on the top, one for hot taps and one for the shower. I would reccommend a dedicated cold supply for the shower from the col water storage tank as well.
Another alternative is an essex flange that fits on the side of the cylinder near the top.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Balenza
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jun 03, 2007 2:35 pm    Post Subject:
Only use a surrey flange if your using a pump.
Otherwise no need. Also no need for a dedicated supply from the cold cistern either.
If you considering installing a gravity shower system think twice unless you have an appreciable head of water available.
__________________
If you cant fix it then leave it so no else will !.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun Jun 03, 2007 2:38 pm    Post Subject:
I would always use a surrey or essex flange even without a pump to eliminate the shower going cold if another hot tap is turned on whilst you are in the shower, vice versa that is why you need a sepearte cold supply from the cold storage tank.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Jun 05, 2007 12:45 am    Post Subject:
Hm. And do you use correct spelling only when using a pump?
Gibberish. The full stops are in the right place though.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Problem with cold water to shower and basin 6 340 Thu Mar 09, 2006 5:01 pm
Cold water to electric shower unit ! 2 360 Tue May 22, 2007 6:23 pm
cold water running through shower 10 2580 Sat Apr 01, 2006 7:59 pm
Valiant Boiler, can't get hot water to shower, but taps work 14 2400 Fri Oct 20, 2006 7:53 pm
Hot water to new shower and basin 9 340 Tue Jul 19, 2005 10:30 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
