DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Silicone seal around double glazing
This topic originated from the How to page called Draught proofing windows and doors
Click here to return to the page called Draught proofing windows and doors.
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
Pame1a
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 14, 2007 12:45 pm    Post Subject:
Reply with quote Thanks
I had double glazing fitted a couple of years ago but the silicone seal between the window frame and the inside wall has now come away from both surfaces in the corners and gaps of a couple of mm on each side of it are present. The silicone is basically not attached to anything in these areas. On the outside, the frame has pushed outwards slightly so the silicone peels back in the corners, especially in summer. Can I remove the silicone and re-seal it with something from a DIY store?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Tanglefoot
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 14, 2007 8:26 pm    Post Subject:
Hi, you just need to remove the old silicone, cut it away with a sharp stanley knife, also to help you get hold of it and pull it off use long nose pliers to help you grip it. It depends on how much the silicone has degraded, it can be quite tough to remove neatly but it just takes a bit of patience. Then once you've removed it all, apply fresh silicone with a silicone gun and smooth and press your bead of silicone with a wet finger.
I'd wait for a good few dry days though first, you want any moisture that's in the to get dried out nicely and you want to apply the new stuff when it's nice and dry too.
Back to top
 Alert Moderators
Pame1a
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 15, 2007 6:27 am    Post Subject:
Hi
Thanks so much for helping me out. I'll have a go when the weather gets better!
Pam
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Fri Jun 15, 2007 7:50 am    Post Subject:
Use low modulus silicone on the outside but on the inside, use a flexible decorators caulk otherwise emulsion paint or wall paper will never stick to it when you come to decorate. If the frame has moved & it's only 2 years old I would call the company that installed it back as it doesn't sound as if the window has been properly installed; hopefully they didn't just stick it in the wall with silicone!
__________________
Richard C
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
removing silicone sealant 2 700 Thu Jan 25, 2007 9:11 pm
Silicone sealant not sticking to uPVC 3 560 Fri May 09, 2008 10:15 am
silicone smears on glass. 2 500 Sun Jul 29, 2007 6:37 pm
B&Q silicone sealant - DISASTER??? 3 1340 Mon Sep 04, 2006 9:15 pm
Removal of silicone filler! 5 720 Sun Apr 01, 2007 6:58 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
