DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Two Lights 1 double switch - How to wire?
Author Message
DoubleTrouble
from United Kingdom
PostPosted: Fri Jun 15, 2007 1:10 pm Reply with quote
I current have a wall switch (double) with 3core+earth and want to know how to wire them to switch 2 lights on/off independantly.
There is only 1 switch needed.
Please see my diagram for details.
Thanks for you help!
Back to top
 Alert Moderators
DoubleTrouble
from United Kingdom
PostPosted: Fri Jun 15, 2007 1:11 pm Reply with quote
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 718 times
PostPosted: Fri Jun 15, 2007 1:12 pm Reply with quote
OK, you should have a 2-gang switch. this will have two sets of C, L1 and L2.
Connect the red to both Cs on the switch (link between the two)
Connect the blue wire to one of the L1 terminals
Connect the yellow wire to the other L1 terminal
I guess that the 3-core cable goes to one of the light fittings?
Connect the red from the other end of the cable to the loop terminal (thats your live feed back to the switch.
Connect the blue wire to the L terminal on the light fitting.
That is one light done.
Now you'll need a piece of two core & earth cable to run between the two light fittings. The wires will probably be blue & brown
At the fitting where the 3 core terminates you'll need a small terminal block (choc block) connect the yellow wire from the 3 core to the brown wire on the 2 core cable. Connect the earth wire to earth!
At the second fitting connect the brown wire from the two core&earth cable to the L connection and Connect the earth wire to earth!
Thats the other light done.
Your light bulbs go between N & L at each light fitting.
The blue and yellow wires must be marked with red or brown sleeve or tape to show they are live!
All earth conductors must be sleeved green&yellow.
That's it.
Back to top
 Alert Moderators
DoubleTrouble
from United Kingdom
PostPosted: Fri Jun 15, 2007 2:02 pm Reply with quote
That a great help cheers!
Would you mind checking over my new diagram to see if I undersood?
Also, would I be correct in saying that the new twin&earth joining cable doesn't have the blue wire used?
Cheers
http://www.flickr.com/photos/8966682@N06/552223479/
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 718 times
PostPosted: Fri Jun 15, 2007 2:45 pm Reply with quote
Looks like u got the idea. You didnt redraw the switch though. Per above, you should have a switch plate with two switches on it - two sets of C , L1 & L2 terminals.
also as the two wire cable will be at the lighting rose 2 you could earth that end too (just pop them all into the earth terminal there.
Yes yr right, the blue conductor is not used.
Good luck
Back to top
 Alert Moderators
DoubleTrouble
from United Kingdom
PostPosted: Fri Jun 15, 2007 2:50 pm Reply with quote
That's great, it'll keep me busy the weekend!
Thanks again for your help.
Back to top
 Alert Moderators
p56
from United Kingdom
PostPosted: Wed Nov 19, 2008 12:16 pm Reply with quote
ive got the same problem in my front room, but it seems that the lighting circuit starts from one of the lights so ive got two sets of mains wires and two white cables. but at the light switch ive got two white cables and one has yellow blue and red? im not sure where that comes from as its not part of the lighting circuit.
can anyone help me sort this out so that the two switches operate both lights independently,
cheers
Back to top
 Alert Moderators
p56
from United Kingdom
PostPosted: Thu Nov 20, 2008 12:51 am Reply with quote
anyone?
Back to top
 Alert Moderators
conny
from United Kingdom
Thanked: 67 times
PostPosted: Thu Nov 20, 2008 6:30 am Reply with quote
You should start your own post not hijack another members.
And try to include diagrams/photos.
Back to top
 Alert Moderators
p56
from United Kingdom
PostPosted: Thu Nov 20, 2008 9:43 pm Reply with quote
oh, i thought that since it was basically a variant of the same question, that it would go in this thread. sorry, pls delete these posts and i will start another thread...
Back to top
 Alert Moderators
mikeyd
from United Kingdom
Thanked: 42 times
PostPosted: Thu Nov 20, 2008 10:15 pm Reply with quote
It's OK, the post you hijacked was a year old so they won't be too upset. When you do start a new post please do explain exactly what color and how many cables and how many cores in each cable are at each light switch and the fittings. Photos are even better.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Two Lights 1 double switch - How to wire switch? 23 5220 Thu Jan 07, 2010 5:10 pm
Two lights, double switch, spare wire! 7 700 Wed Nov 04, 2009 10:48 am
i have bought a double dimmer switch but having trouble wire 10 100 Mon Nov 14, 2011 12:07 pm
Replacing double dimmer with double switch. Bridge wire? 5 140 Sun Oct 21, 2012 5:14 pm
Earth wire on double socket 2 940 Sun Nov 27, 2005 12:00 pm
DIYnot
