Hi, I'm hoping you guy's can give a little advice. I've just moved into a house which has been stood empty for about 5mths. It has a Vaillant ecoMAX 800/2 combi boiler which was fitted in 2001, which has been fired up occasionally by the previous owner who now live in the IofM (uncontactable).
The problem is that there is no hot water and whilst the dials are showing 1/2 temp for both the water and rads, when the hot tap is opened the rads get hot, but the water is still cold.
I have learnt that the pressure should be running at between 1.0-1.5bar but it shows only a 0.8bar reading. I'm told that this is a simple task of filling the boiler...but how and will it solve the problem.??
Is there a valve which switches over the hot tap and the radiator...and could it be sticking....?
The system has a built in problem and diagnostic tester and it shows (5.14) that all the system is operating well...!!
