DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Kitchen mixer - hot tap won\\\'t turn off
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
gella
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 25, 2007 9:03 am    Post Subject:
Reply with quote Thanks
Monday morning, my hot water tap wouldn\\\'t turn off on my kitchen mixer this morning.
I took the hot tap handle off and tried to reset it in a different place on the cogs but it still wouldn\\\'t turn off - only seems to turn a 1/4 turn!!! Was running late for work so turned it off at stop tap!!!
Please help as I know mixers don\\\'t have washers so what\\\'s happened?
Yours hopefully
Ali
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Mon Jun 25, 2007 10:38 am    Post Subject:
You will need to change the cartridge.
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
gella
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 25, 2007 10:41 am    Post Subject:
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Mon Jun 25, 2007 10:45 am    Post Subject:
Quote:
Thank you but what is a cartridge?
The insides of the tap which open and close. Once you take the tap handle off the cartridge, you will see that they are screwed into the tap body icon_biggrin.gif
__________________
Back to top
 Alert Moderators
gella
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 25, 2007 10:47 am    Post Subject:
Marvelous. I'll have a go later on tonight and will let you know if all is well tomorrow or if I have a swimming pool in my Kitchen.
cheers
Back to top
 Alert Moderators
gella
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 27, 2007 1:05 pm    Post Subject:
icon_redface.gif Well the valve has arrived and I've stripped the tap down in order to remove the old valve but guess what? I'm too weak to shift it, whilst pulling on the spanner it feels like I'm going to pull the whole tap out of the socket!! Any ideas? Tips? does something else need to be removed in order to unscrew the valve?
Back to top
 Alert Moderators
payne165
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 27, 2007 1:17 pm    Post Subject:
Could be reverse thread???
Back to top
 Alert Moderators
gella
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 27, 2007 1:41 pm    Post Subject:
icon_confused.gif which means what? I've tried removing it in a clockwise direction - no anti-clockwise......
Back to top
 Alert Moderators
payne165
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 27, 2007 2:19 pm    Post Subject:
Not sure if its the same with yours but my mixer is one side clockwise and the other anticlockwise. same with the threads in the barrel. think its so when you turn the tap on you are not unscrewing the barrel as well?
Back to top
 Alert Moderators
gella
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 27, 2007 2:25 pm    Post Subject:
icon_rolleyes.gif Thank you...will give it a go.
Back to top
 Alert Moderators
bobthebender
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 27, 2007 2:27 pm    Post Subject:
Back to top
 Alert Moderators
gella
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 27, 2007 2:31 pm    Post Subject:
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Wed Jun 27, 2007 5:39 pm    Post Subject:
Try trying to tighten it first. As a last resort could try heating with a blow lamp, but might lose finish on tap icon_eek.gif
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
petetheleak
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 27, 2007 5:54 pm    Post Subject:
You need to eat your porrage in the morning an get along to the gym . no seriously try a ring key spanner on it .Has to turn anti clockwise .
Back to top
 Alert Moderators
gella
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 28, 2007 7:29 am    Post Subject:
Well guys its done - i'm afraid it took a man to do it but even he struggled and had to use WD40 and BRUT force... However, the tap is now working perfectly....Was going to swap out the cold tap valve but BRUT force and WD40 wouldn't move it....just have to wait until I can find a stronger man. Thanks for all your help and support. Ali G icon_biggrin.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
quarter turn monobloc kitchen taps question 2 820 Sun Sep 16, 2007 1:32 pm
Croydex H2O Hydro-Powered Mixer Shower won't turn off 2 1460 Mon Jan 16, 2006 7:41 pm
Mixer shower is hard to turn off 2 640 Mon Nov 14, 2005 10:42 am
localised squeeling noise when I turn on mixer tap in bathro 2 240 Mon Oct 23, 2006 9:57 am
Mira Mixer Shower Difficult to Turn Off 8 840 Sat Jul 22, 2006 11:15 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
