DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Wetroom construction
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
DAZB
from United Kingdom
Thanked: 89 times
PostPosted: Sat May 08, 2004 7:40 pm Reply with quote
I am in the process of renovating a very large house and converting it into 5 flats and in two of the flats I am hoping to build a wet room style shower area and what I am looking for is a recommendation of a product to fit on the floors to create the waterproof sub floor before the tiles are laid. I have looked at a system called Wedi Board which is like a foam panel with a cement impregnated coating which is cut to size and screwed down with washers and screws and then the joints are taped and filled etc, but what I really want is to have a one piece floor ' tray ' or similar and therefore less chance of a leak. I have had a suggestion that there is a one piece copper layer on the market that is laid and the edges are rolled up the walls and the tiles overlay this but have not been able to find a UK supplier. The shower areas are about 1.5m X 1m being rectangular in shape with a raised step into the room of around 5" to form the water barrier. Any advice or suggestions are welcome. Thank you.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sat May 08, 2004 8:05 pm Reply with quote
butyl rubber pond liner?
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Sat May 08, 2004 8:28 pm Reply with quote
or hot pour bitumen ?
fibreglass ???
Is the floor wood or concrete ?
Back to top
 Alert Moderators
Scoby_Beasley
from United Kingdom
Thanked: 50 times
PostPosted: Sat May 08, 2004 11:19 pm Reply with quote
I'd go for the fibreglass matting.
Back to top
 Alert Moderators
DAZB
from United Kingdom
Thanked: 89 times
PostPosted: Sun May 09, 2004 12:44 am Reply with quote
The floor at the minute is 22mm T & G floorboard.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Sun May 09, 2004 3:12 am Reply with quote
I think the problem with copper is the reaction from the cement will eat it away but takes years, stainless steel plate made up into a tray if you can afford it or as Breezer's pond liner idea or maybe a DPM heavy duty gauge.
I suppose you could use 600mm wide lead flashing and cut it in half then weld it together or hook it together, I've just bought 3m x 600mm from Jewson at 35
The tray & waste pipe would have to be above this as well unless through the wall.
Back to top
 Alert Moderators
DAZB
from United Kingdom
Thanked: 89 times
PostPosted: Sun May 09, 2004 6:16 am Reply with quote
I am definately looking more along the lines of a solid prefabicated tray with a very slight run off towards the centre where the drain outlet will be . I will be laying 18mm marine ply onto the floorboards and a hole will be cut through both skins and the waste trap and plumbing will all be housed between the floor joists to pick up the new pipework I have installed. My main aim is to achieve something that will never leak and that also looks good but I realise that I may have a problem tiling over a thin gauge steel tray because of movement unless the tray is of such a quality / look that it won't need any other covering. I have a fabricator I have used for stainless splashbacks before so I will run that option past him on Monday but thanks for your ideas and if you have any to add feel free.
Back to top
 Alert Moderators
Fliptop Ford
from United Kingdom
PostPosted: Mon May 10, 2004 9:08 pm Reply with quote
The stainless tray sounds like the perfect solution to the 'never leak' requirement, but I see two problems - it will have to be made up to fit the room in one piece probably welded together from two sheets ( 8' x 4' usual size ) it will be really heavy and awkward to handle you might not even get it through the door. Second is that it will be incredibly slippy when wet- you will need to use a timber or rubber kind of decking over it which is painful on the bare feet!
Back to top
 Alert Moderators
DAZB
from United Kingdom
Thanked: 89 times
PostPosted: Mon May 10, 2004 10:36 pm Reply with quote
Good points FF and welcome in but it doesn't matter on the size or weight that much because I am renovating the entire property and the bathrooms are going to be created from scratch with two bathrooms being created side by side in the centre of the house with one accessable from the rear flat and the other from the front flat which means I can fit the trays in first then build my stud walls around them if I have to but 1.5m X 1m is not all that big really so it doesn't worry me just yet. With regards to the slippiness of the stainless, will it be any more slippy than a tiled floor ?
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Tue May 11, 2004 8:06 am Reply with quote
I thought the tray is going underneath your tiles or have I read it wrong ?
For info - you can get 1mm thickness stainless steel which is not heavy and also it can be it threaded imprint for non-slip.
Back to top
 Alert Moderators
DAZB
from United Kingdom
Thanked: 89 times
PostPosted: Wed May 12, 2004 12:22 am Reply with quote
Masona........In my first post I was looking at an option of either making up a base from a membrane type system or the other choice was to fit a one piece tray type set up so i can then leave it as is if it is pleasing on the eye or have the option of tiling it if it warranted it so if I fit the stainless tray I won't need the tiles and vice versa. It is still early days on the timescale of the job yet but I was just planning early before I had the plumbing done. I will more than likely be going with the stainless tray method as it seems the most leakproof option.
Back to top
 Alert Moderators
1stTC
from United Kingdom
PostPosted: Mon Jun 21, 2004 2:58 pm Reply with quote
Try here:
[url] http://www.boundarybathrooms.co.uk/acatalog/copy_of_WetFloorDrains.html[/url]
They have a telephone enquiry service and are very helpful.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Mon Jun 21, 2004 5:01 pm Reply with quote
See this
1stTC,
Your link not working so I've done it for you.
To help you, this is what it should look like,
See [url=http://www.boundarybathrooms.co.uk/acatalog/copy_of_WetFloorDrains.html ] this [ /url]
Back to top
 Alert Moderators
AFH Dan
from United Kingdom
Thanked: 1 time
PostPosted: Sat Jul 03, 2004 2:10 pm Reply with quote
Hiya,
The way I would go about it is to make the fall in the floor out of marine ply, sink a trap where you want the water to run to an outlet and then use a product call WP1 (water protection 1) made by BAL (Building Adhesives LTD) www.nxadh.co.uk to seal not only the floor to the trap and the floor generally but you can run this up all of the walls to a certain hight (next to shower heads etc).
This is tried and tested and works. It is also a cery inexpensive way of going about making a wet room. icon_smile.gif
Hope this helps.
Regards
Dan
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Sun Jul 04, 2004 3:29 pm Reply with quote
Dan,
I cannot open the website link, is it correct or it is me ?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Help With Tiny L Shaped Wetroom 2 100 Mon Mar 21, 2011 1:08 pm
Wetroom in Loft 44 18840 Sun Apr 30, 2006 7:20 pm
concrete screed for wetroom installation 4 300 Wed Sep 08, 2010 12:11 pm
toilet/ wetroom drainage 6 140 Sat Aug 27, 2011 7:09 am
Wetroom floor - dry rot insulate or not? 3 560 Fri Nov 07, 2008 11:15 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
