hasso
Joined: 01 Jul 2007 Posts: 13 Location: United Kingdom Thanked: 0 times
Posted: Sun Jul 01, 2007 6:44 pm Post Subject: alarm only shows power not day light. |
i have a optima compact g3 alarm at my tentants house anyway ages ago it just kept goin off so i just switched it off so today i decided to switch it back on it came on but it only showed the power button and the outside sounder kept goin off so i pressed every button and nothing happend so i just left it . can any one please help me as new tenants are arriving soon |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sun Jul 01, 2007 6:55 pm Post Subject: |
what the panel made no noise when asny button was pushed?
sonds like its gone into alarm condition, needs the cutomer code, you might try 0123 __________________ Do you like music Mr Finch?
Forum = Opinions |
scott1980
Joined: 03 Mar 2006 Posts: 84 Location: Manchester, United Kingdom Thanked: 3 times
Posted: Sun Jul 01, 2007 9:35 pm Post Subject: |
Seen this 100 times before on Optimas/Accentas etc. Basically, any low end panel will do it. It's due to a duff battery back up in the panel causing it to lock up when the mains supply is turned off and then back on again. No response from the keypad and no mains indicator light even though there is a mains supply is a good indicator of this problem. It's also the reason your bell box sounds when the mains is interrupted. Replace the 12v 2.1ah battery inside the control unit. |
hasso
Posted: Mon Jul 02, 2007 2:53 pm Post Subject: |
nope i tryed every buttin but nothing happend thanks for the reply |
hasso
Posted: Mon Jul 02, 2007 2:54 pm Post Subject: |
scott i will try a better are u 100% sure it will work i got some spare alarm batteries |
lvsystems
Joined: 28 May 2007 Posts: 183 Location: Surrey, United Kingdom Thanked: 0 times
Posted: Mon Jul 02, 2007 3:46 pm Post Subject: |
Will either be the panel has defaulted in which case try the default code I think is 0123 or 1234 if that doesn't work then the NVM may of been corrupted by a spike. Try the codes and if that doesn't work you could try leaving it powered down for a few mins just have to put up with hthe outside bell and then power up mains first. __________________ Do it yourself, it'll be fine. Whats the worse that can BANG happen |
