DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Cutting hole in stainless steel sink
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
rcs
from United Kingdom
PostPosted: Fri Jul 13, 2007 8:22 pm Reply with quote
Hi
What is the best way to cut a hole in a SS sink for the tap? I've seen hole cutters which use a shear action and a through bolt but don't know what they're called.
Many Thanks
rcs
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1436 times
PostPosted: Fri Jul 13, 2007 8:37 pm Reply with quote
sheet metal hole punch?
But be aware that stainless steel is very hard so make sure the tool you buy is not sold "for mild steel and brass" which are easier to work.
Back to top
 Alert Moderators
em_on_bread
from United Kingdom
PostPosted: Fri Jul 13, 2007 8:40 pm Reply with quote
ikea sell one - i think its called 'fixa'. it took us three hole cutters and 2 sinks to finally cut a hole through the sink though. very hard work.
Back to top
 Alert Moderators
cozzmic
from United Kingdom
Thanked: 58 times
PostPosted: Fri Jul 13, 2007 9:17 pm Reply with quote
Brand new bi metal holesaw with cutting paste/oil, battery drill and off you go.
I thought it would take ages but was done in a matter of minutes.
Watch the sharp edges.
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 407 times
PostPosted: Fri Jul 13, 2007 9:30 pm Reply with quote
The cutter you mean are called Qmax and are available from
http://www.lawson-his.co.uk/scripts/products.php?cat=Hole%20Cutters
You will need a very sharp (brand new) drill for the pilot hole and you will need to centre punch the hole before drilling the pilot otherwise it will skid all over the place icon_eek.gif
Back to top
 Alert Moderators
rcs
from United Kingdom
PostPosted: Sat Jul 14, 2007 6:46 am Reply with quote
Thanks for the replies. Don't know if q-max will cut stainless but will try and let you know.
Cheers
rcs
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 407 times
PostPosted: Sat Jul 14, 2007 8:15 am Reply with quote
Qmax will cut stainless steel sinks. I have used them to install the small filtered water type taps on several occassions.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3437 times
PostPosted: Sat Jul 14, 2007 10:42 am Reply with quote
The Q-Max will only cut SS if they are in very good condition and its best to lubricate the cutting part and the thread.
Its possible to buy TC tipped metal drills which are fine for SS and c.i.. These are NOT masonry drills!!!
I have not tried it but a diamond bur in a Dremmel style drill should work and could be used to make non circular holes too.
Tony
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 407 times
PostPosted: Sat Jul 14, 2007 11:15 am Reply with quote
I had assumed the OP would be buying a new cutter so should be in good condition, no?
Good tip about the lubrication though - cheers, Tony.
Back to top
 Alert Moderators
timmy74
from United Kingdom
PostPosted: Sat Jul 14, 2007 3:49 pm Reply with quote
been there took me nearly an hour icon_twisted.gif icon_twisted.gif customer said he'd cut the utility one out said it took him 30 mins with a ratchet.. i thought get on with it icon_biggrin.gif
Back to top
 Alert Moderators
rcs
from United Kingdom
PostPosted: Sat Jul 14, 2007 6:58 pm Reply with quote
Being a Saturday and all the good tool stores closed, I decided to use the Dremel option which worked with no problems. Tap now fitted and Wife off my case, lol!
rcs
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Pin hole in stainless steel sink 9 180 Tue Mar 25, 2014 12:53 pm
New hole in stainless steel sink for filtered water or mixer 5 580 Tue Jul 22, 2008 9:36 pm
Searching for Small Stainless Steel Sink 3 80 Tue Apr 23, 2013 4:50 pm
Recommendations for good stainless steel sink please? 3 260 Tue Aug 04, 2009 9:33 am
stainless steel kitchen sink not tight to unit 3 60 Sun Mar 24, 2013 7:13 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
