Fitting a 30mm holesaw into a 6mm chuck - is this right?
27 Jul 2007
Hi all,
As the title suggests I need to fit a 30mm hole saw into a 6mm chuck.
Is this the right thing to buy?
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=10531&ts=15342
The chuck is on the end of a flexible drill shaft and I have looked high and low for a larger chuck for a flexible drill but apparently they do not exist anywhere in the world?!
Thank you!
Sounds a bit dodgy to me, a hole saw should be used directly into the drills chuck not through a flexible drive. If it bites it might brake your wrist.
The arbor your show looks OK.
I hope I read your post correctly.
JonB
I think you did JonB. Thanks for the reply.
Its not an ideal situation but I'm drilling a 1 inch thick piece of soft wood through the most inaccesible 6cm hole known to man and no drill will 1) fit through the hole or 2) bend in that direction.
I am drilling at a slow speed, with the hammer action off so it should be OK.
If you or anyone can think of a better suggestion I am more than happy to take it on board. Believe me, this is a last resort.
Right angled drill any good? There are cheap adaptors...
I use one with a chopped off flatbit for floor joists.
