Hi all
My hot water cylinder has a slow leak at the following connection:
Access is a bit of pig as you can see...what am I looking at here for a resolution?
Full drain down, disconnect everything, rotate cylinder and replace connection?
Re-plumb connection to entirely new joint and put an end stop on the existing pipe?
Or try and nip it up, in the hope that it doesn't destroy the connection and chuck nasty water everywhere?
Just seeking some advice about the best way to proceed here. Many thanks.
